Billet Aluminum Thermostat Housing for 4.0L 1GR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1GR-FE<3R, Oct 20, 2022.
  1. Nov 7, 2022 at 12:51 PM
    #101
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I'm looking at getting the motorad 170. For mine.
    BassAckwards likes this.
  2. Nov 7, 2022 at 1:30 PM
    #102
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I don’t think the high flow is ment for better cooling. Just more flow. I’d go with the high flow. I’ll be curious during the heat of summer.
  3. Nov 7, 2022 at 2:51 PM
    #103
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I went with the 160 for mine. Need to install still but that's what I've been running for years now. Very hot here in the Arizona desert.
    Torspd likes this.
  4. Nov 7, 2022 at 4:01 PM
    #104
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    What temperature your thermostat opens at doesn’t mean your engine is going to run any cooler. It’s going to get up to exactly the same temperature anyway it will just take another 73 seconds.
    JustDSM and Mully like this.
  5. Nov 8, 2022 at 5:18 AM
    #105
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Right, but like you said it takes longer to get to temp. Opening earlier to help combat hot/climbing temps. It's already 120 out.. why not let it open up sooner. Especially being boosted.
    Mully likes this.
  6. Nov 8, 2022 at 6:31 AM
    #106
    $yoda$
    Tom
    2007 Tacoma 4.0
    Because it makes no difference. Your engine is still going to climb to running temperature extremely quickly especially with outside temperatures that high. Having your thermostat open a few degrees sooner is completely pointless. It helps nothing. You could remove it completely and your engine will still run at 190-200. The thermostat is only there to get your truck up to temp as efficiently as possible.
    1GR-FE<3R[OP] likes this.
  7. Nov 8, 2022 at 7:02 AM
    #107
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Not exactly "true." If the other aspects of your cooling system are upgraded, there can be lower operating temperature range, that could not be had without a lower opening temp t-stat. It never stops how hot the engine can get. It does allow it to operate at a lower "normal" temp though.
  8. Nov 8, 2022 at 7:19 AM
    #108
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    I ran the 160f thermostat for a while and couldn’t get my truck up to normal operating temps even during the summer. I don’t think this is entirely true ?
    1GR-FE<3R[OP] and Torspd like this.
  9. Nov 8, 2022 at 7:58 AM
    #109
    1GR-FE<3R
    1GR-FE<3R [OP] Well-Known Member
    Cody
    For those that are interested I have sourced 170° thermostats! I have not got a solid source yet so we do not have a ton of the 170° stats but the option is on the table!
    We now have 160° standard flow, 170° standard flow, 180° standard flow, 180° high flow, 195° standard flow!
    TodayWasTHeDaY likes this.
  10. Nov 8, 2022 at 8:08 AM
    #110
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Im going to bump this again, unless you have a custom tune ... you will want to stick with stock temp tstat.
    I can look up the actual temp in HP tuners (its been awhile since i have messed with my tune). But I dont think it actually runs the O2 sensor checks wile running under load until the coolant temp is 183... if you dont get to that for a consistent enough time, those checks wont run and you will throw a code.
    JustDSM and 1GR-FE<3R[OP] like this.
  11. Nov 8, 2022 at 8:11 AM
    #111
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Got a part# for the 170°?
    1GR-FE<3R[QUOTED][OP] likes this.
  12. Nov 8, 2022 at 9:11 AM
    #112
    1GR-FE<3R
    Cody
    100% I agree with you on being tuned to run the cooler thermostat… I am getting conflicting info from a couple different tuners regarding if the check engine light will actually come on…
    I have a couple saying it will stay in open loop and waste more fuel attempting to warm itself up and it may or may not throw codes.
    Another tuner is saying he has never seen a check engine light on for cooling system not reaching temp or thermostat insufficiency. And he typically has the customer install the cooler thermostat the week prior to tuning…
  13. Nov 8, 2022 at 11:01 AM
    #113
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    FWIW, I've never had an issue or thrown a code regarding it getting up to Temp with the 160 and HP Tuners tune.
  14. Nov 8, 2022 at 11:09 AM
    #114
    nd4spdbh
    SoCal
    Likely because your tune has factored in the lower temp tstat, and 2, you live in a warmer climate to where temps are above the threshold often enough.
  15. Nov 8, 2022 at 11:20 AM
    #115
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    correct. the environment being the main factor imo.
  16. Nov 8, 2022 at 11:35 AM
    #116
    garciav
    Houston, TX
    TRD SC,HPTuners
    does your engine temp get above 173 ?
  17. Nov 8, 2022 at 11:37 AM
    #117
    garciav
    Houston, TX
    TRD SC,HPTuners
    you will throw code P0128 and the truck will be stuck in high idle
  18. Nov 8, 2022 at 11:38 AM
    #118
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yes.. usually right around 190 +/- 10 degrees depending..
  19. Nov 8, 2022 at 11:41 AM
    #119
    garciav
    Houston, TX
    TRD SC,HPTuners
    that’s probably why you’ve never thrown a CEL for temps or had issues.
    I ran the 160F for a while, in the summer months it was great no issues but fall/winter the engine temps couldn’t get above ~168. This would throw a CEL after a while and the truck would get stuck in high idle.
    1GR-FE<3R[OP] and JustDSM like this.
  20. Nov 8, 2022 at 11:44 AM
    #120
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    That's why I think the environment and ambient temps play a larger factor for me and my truck. BUT.. we do go cold weather camping.. and it still has never had an issue with getting up to temp... so that's probably the Tune coming into play as well.
