Billet Aluminum Thermostat Housing for 4.0L 1GR-FE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1GR-FE<3R, Oct 20, 2022.
  1. Nov 30, 2022 at 8:26 AM
    #141
    1GR-FE<3R
    1GR-FE<3R [OP] Well-Known Member
    Cody
    You hit the nail in the head! The main goal was to offer an aluminum housing that corrects all the plastic housing failure points… there was so much time waiting to have it made I started to think of ways to improve it… first being to make the thermostat replaceable, lots of options…
    We did make versions that mimicked the plastic housing with the “fingers”. It was not worth the trouble. The factory spring loaded thermostat proved pretty difficult to swap and it cannot be bought separate… everyone would need to reuse their old thermostat or buy a new plastic housing to rob the thermostat out of it, I was not cool with people not having a complete solution. Lol I think we got it now!
    You are correct with regard to the cooler thermostats. We don’t recommend running them unless you are tuned. We offer a 160°(Mishimoto replacement) and a 170°(URD replacement).
    As far as which 180° thermostat to run it depends on your climate zone. A 180° standard flow thermostat has no problem keeping your vehicle cool in any climate. The 180° high flow thermostat is going to have greater benefit when in hotter climates 100°+ but it will not adversely affect warm up times, it is still a 180° thermostat.
    On another note, there are 180° failsafe thermostats (fail stuck open) as well, I am not a huge fan of those but the option is there. And I can understand why one would prefer to run it in certain situations.
    12TRDTacoma, Torspd, Mully and 2 others like this.
  2. Dec 3, 2022 at 2:30 PM
    #142
    1GR-FE<3R
    Cody
  3. Dec 13, 2022 at 5:07 PM
    #143
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So, I'm not sure if any other S/C'd guys have installed this yet.. or tried to.. but the housing interferes with the S/C belt.
    Just got home after picking up the truck from having some work done including having them throw in the new housing while they were in there. Apparently the shop didn't check it very well.. will deal with it/them tomorrow, but wanted to share asap before others ran into this issue and let you know @1GR-FE<3R
    PXL_20221214_002617361.MP.jpg PXL_20221214_002630494.MP.jpg PXL_20221214_002639410.MP.jpg PXL_20221214_002946966.MP.jpg PXL_20221214_003028122.MP.jpg
    12TRDTacoma, Torspd, wi_taco and 2 others like this.
  4. Dec 13, 2022 at 5:50 PM
    #144
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Glad you found out. We would have during the engine swap, but were waiting on a 170°, so it missed the window for install.
    12TRDTacoma and XPOTRPR like this.
  5. Dec 13, 2022 at 6:08 PM
    #145
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Was wondering if you guys got to it. Looked to see if you mentioned anything prior to posting. Just going to order a new housing and slap in another 160
    12TRDTacoma and Torspd[QUOTED] like this.
  6. Dec 13, 2022 at 6:19 PM
    #146
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Do you think part of housing can be shaved down, say 1/4" or whatever amount you think, without compromising anything strength wise?
  7. Dec 14, 2022 at 5:13 AM
    #147
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I don't honestly. The larger/main housing portion is the biggest issue, but even if that was clearanced enough, it looks as if it would still make contact with the smaller/piping portion. I don't think there's enough material to remove without jeopardizing anything. Just my observations so far.
  8. Dec 14, 2022 at 7:07 AM
    #148
    TodayWasTHeDaY
    Russ
    Calgary
    Well that just sucks. Giant paperweight now and they will be more than a couple for sale shortly from the SC crowd.
    henryp and 12TRDTacoma like this.
  9. Dec 14, 2022 at 7:51 AM
    #149
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I mean.. maybe its possible.. would need to hear from @1GR-FE<3R and his shop. Not sure how much material they have to play with, if any.
  10. Dec 14, 2022 at 8:24 PM
    #150
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Sonovabish. I just got around to revisiting this mod for us boosted boys again and come to find out it's a giant heartbreaker on what is otherwise quite a lovely made billet item. God that sucks. I was actually going to add it to Page 1 but my methodology of waiting for things to clear before adding to the OP prevails. If one of our boys lives by him and he is willing to work with them, perhaps we can get a T-stat version adapted for us boosted boys as well and he will be able to offer two different versions of it. Perhaps?! Who knows!
    My hat goes off to @1GR-FE<3R for making this available to the community. STELLAR work Cody, keep up the good work!
  11. Dec 15, 2022 at 1:20 AM
    #151
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Patience folks. As we know, these first design versions were never fitted on supercharged engine. If material is available to be removed without compromising the integrity of the housing, I highly suspect a revision to remove that material will be made. If inadequate material is currently there, slightly altering the affected area internally without compromising flow could happen.
    The housing as is a quality item, and the guy selling them has been straightforward so far.
    Give it a bit of time, this is not like McDonalds where you instantly get your order redone.
    Worse case, you get a refund. Stay excited to get these, so then the OP has desire to make the change vs listening to complainers. It will get worked out.
    montijo505, TodayWasTHeDaY and Mully like this.
  12. Dec 15, 2022 at 4:32 AM
    #152
    TodayWasTHeDaY
    Russ
    Calgary
    100% agree.
    It's disappointing, especially to @XPOTRPR, but the fact remains that the piece is really well made, the idea behind changing thermostats in the housing is genius, and it is a product for tacos. Those are all wins.
    I'm on board for the revision for sure.
  13. Dec 15, 2022 at 5:31 AM
    #153
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh boy, trust me.. I know about revisions. Lol Good things come in time. I'm not upset about it at all tbh.
    I told Cody I am more than willing to wait and try a revised housing to do another test fit. The Taco isn't my main my vehicle so I have no problem with it sitting for testing purposes. I myself have sent parts/products to people to get feedback and testing done. It has helped me greatly in the past. So if I can return the favor and help, I will.
    This weekend when I get some time, I plan to dig into it a bit more and hopefully get some measurements and better photos.
    Torspd and TodayWasTHeDaY like this.
  14. Dec 15, 2022 at 6:34 AM
    #154
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Shoot. Another paper weight to add to the list.
  15. Dec 16, 2022 at 2:16 AM
    #155
    PMK
    Florida
    10 DCLB TRD Sport
    My patience remark was not at you, others are a bit harsh in their words.
    Torspd likes this.
  16. Dec 22, 2022 at 8:22 AM
    #156
    1GR-FE<3R
    Cody
    Sorry for the delay in responding to everyone… we are working on the redesign for the supercharged vehicles… anyone who purchased one for a supercharged 4.0 please be patient and we will gladly swap it out for the redesign!
    PMK, Mully, Torspd and 6 others like this.
  17. Dec 22, 2022 at 8:32 AM
    #157
    henryp
    Henry
    Montana
  18. Jan 14, 2023 at 5:45 PM
    #158
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    thanks cody. looking forward to a swap and bolt on.
    1GR-FE<3R[OP] likes this.
  19. Jan 22, 2023 at 7:33 PM
    #159
    tselanne
    tselanne Active Member
    2023 Tacoma Sport 6sp manual
    Sorry if stupid question, I'm new to Toyota. Will this product fit on a 3.5L?
    1GR-FE<3R[OP] and Pearson like this.
  20. Jan 23, 2023 at 7:35 AM
    #160
    drewnali
    drewnali Well-Known Member
    Drew
    Dunnellon Florida
    2013 4X4 SSM TRD OR DCSB
    Just ordered mine! Always stoked to find better than stock replacements.
    1GR-FE<3R[OP] and Mully like this.
