Billet Grill Installation on 2011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by avengedkevinfold, Jan 9, 2011.
  1. Jan 9, 2011 at 6:42 PM
    avengedkevinfold
    avengedkevinfold [OP] Well-Known Member
    Kevin
    Socal - OC - Huntington Beach
    bilstien 5100s all the way around, ICON progressive 3 leaf kit, Illegal tint, snuglid SL, seatbelt chime mod. light racing UCAs
    No longer looking to do this. Please do NOT PM me about trading my grill for an older grill cause it won't happen.
  2. Jan 9, 2011 at 7:01 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    There is probably a ton of guys that would trade you their grill for yours. Once you have done that you wouldn't feel so bad for cutting it up. lol
  3. Jan 9, 2011 at 7:54 PM
    xenadogs
    xenadogs Active Member
    LA / OC
    2011 Sport DC MGM
    Debaged, Matching Tonneau cover, Grill Craft, Seat covers
    It will be fine! Cut the triangles as flush as possible then grab a file and file them down. The only way one can tell is if they get a flash light and study the damn thing. My 2011 grill craft mod came out fine.
    Just do it!
  4. Jan 9, 2011 at 9:31 PM
    avengedkevinfold
    Kevin
    Thanks for the advice. Good to know I'm not the 1st to do it on the 2011. Can you post some pics? Also, whats the trick to disassemble the hood skoop?
  5. Jan 10, 2011 at 5:10 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 Dbl Cab LB 4x4 TRD
    Toytec CO's, IRONMAN rear leaf pack, All pro front bumper, Body Armor rear bumper, BA steps MB TKO's w/285/75/16 Terra Grapplers, Bakflip tonneau cover, autopage remote start alarm, Ultragauge
    That kit you are looking at is made to attach over the factory grill like mine. It comes with L-brackets that hooks to the factory grilles and tightened with supplied screws/nuts. It will sit flushed if tightened enough. The hood scoop grill sits over the metal factory mesh and will require you to drill holes through the back plastic to secure the grille.Same with the triangle pieces. I didn't use the hood grill because I like the factory setup(a little too much IMO). I heard of guys cutting the factory grill for a custom look but it will weakened the setup since the grille is a little heavy and you will get more "radiator see- through" w/o the factory center piece. Install is a snap, especially if you take the factory grille off the truck. Keep in mind you can go back to stock easily if the center piece is left intact.
  6. Jan 10, 2011 at 5:21 AM
    l_prettyman
    l_prettyman Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    yeah i would trade my satoshi'd grille for your 2011 grille! then its really easy to do the mod cause everything is already done
  7. Jan 10, 2011 at 10:58 AM
    KevinD
    KevinD I don't say to much
    Kevin
    NC
    09 PreRunner X-SP silverstreak
    Billit grill and window tent, HIDs, fog light mod
    Mine is a little different than the one you want but it should install just the same as the way Wattapunk discribed. Its very clean and easy.
  8. Jan 10, 2011 at 11:18 PM
    avengedkevinfold
    Kevin
    T-Rex Grill install PDFS
