Billet Res Clamps, Spark Plugs, Springs, Gas Tank Skid, R&P, Tire and Wheel
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by IFS4LIFE, Jun 20, 2015.
  1. Jun 20, 2015 at 5:37 PM
    IFS4LIFE
    IFS4LIFE [OP] Well-Known Member
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    All items are located in Tucson and I accept PayPal. I can ship any of it on your dime.
    35X12.5X15 MFG Mud Terrain OG. Date Code 4005, 6 on 5.5" pattern. $225 with the wheel, $75 without the wheel. Roughly 7/16" tread depth. Figure it's a $30 Rim, $50 Tire, $60 beadlock, $100 in hardware, so you get a nice free install on the beadlock.
    2.5" X 14" X 650 LB Sway Away Springs $50
    Leaf Springs with 6" AOR Shackles and Greasable hardware. One Bolt needs a new zerk. $100
    3.4 5 Spd. Short Throw. Machined by me, not URD. $125
    Fuel Tank (No Sending Unit, has been outside for about 6 Months) $40
    1.75" to 2.5" Billet Res Clamps. $50 for the pair
    6 IK22 Plugs. Never been out of the Box. I ordered them, then the 7th injector kit and they were included. $50.
    Limit Straps. 1 Pair 24" Long. 1 Pair 25.5" Long. $40 Per Pair
    Plug and Play Trailer Harness. 4 pin. $25
  2. Jun 21, 2015 at 5:05 AM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    PM'ed re: gas tank skid.
  3. Jun 23, 2015 at 6:08 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Gas Tank Skid: SOLD!
  4. Jun 25, 2015 at 3:36 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Canoe Added $250 OBO
    15' with 2 vests and 3 flotation cushions, in the event of a water landing, and 2 AL paddles.
  5. Jul 3, 2015 at 9:48 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Gas tank Skid received, Thanks ISFS4LIFE!
  6. Jul 3, 2015 at 7:55 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Glad you got it. Surprised it wasn't there sooner. Thanks again.
  7. Jul 4, 2015 at 5:38 AM
    travelfeet
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    UPS notified me of a weather delay in Ohio, so took a couple extra days.
  8. Jul 5, 2015 at 11:54 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    What else is needed to install those 4.10's?
  9. Jul 5, 2015 at 8:39 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    What gear ratio do you have now?
  10. Jul 5, 2015 at 9:02 PM
    boostedka
    James
    NM
    3.91 on a 2.7L
  11. Jul 5, 2015 at 9:50 PM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    You might have to swap the carrier out as well since you currently have the 3.91's. I'm not sure though. Aside from that you'd need an install kit as well as matching gears for the rear.
  12. Jul 20, 2015 at 9:38 AM
    MK ULTRA
    MK ULTRA Well-Known Member
    JIM
    Huntsville Ala
    4X4
    How many miles on the leaf springs and are they stock or upgraded. Will you ship
  13. Jul 20, 2015 at 9:55 AM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    The main leafs were replaced at about 150K and I put 30K on those. I installed an AAL at about 140K. They are well used and pretty much sat flat with my truck before before I pulled them, but they did flex well which was my only concern. I can ship them. Cost to Alabama would probably be in the $60-$100 range.
  14. Feb 11, 2016 at 11:39 AM
    IFS4LIFE
    Tucson
    98 Tacoma 4X4
    Stock.....ish
    Ring and Pinion Sold. Bump
