Billet Tie Downs - Memorial Day SALE
Discussion in 'Automotive Group Buys' started by Charvonia Design, May 24, 2023.
  1. May 24, 2023 at 12:56 PM
    Charvonia Design
    Charvonia Design [OP] Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 TRD Off Road Bronze Oxide
    Hey TW! It's been awhile since we had a sale on Billet Tie Downs, so let's do one for Memorial Day!
    Use code TWMEMORIALDAYGB to get the discount.
    Free shipping will still apply for orders of 2+ items.
    And now....some info on Billet Tie Downs in case you haven't already seen them:
    These are a direct replacement for the steel U-shaped hooks that are bolted in your bed. Available in red, black, blue or silver, the patented slot keeps your ratchet strap hook from falling out while you tie things down. There are also multiple ways to attach bungees, rope or ratchet straps.
    Sold in pairs
    • Application: 2007-2023 Toyota Tundra (uses two pairs, or four Bed Tie Down Anchors)
    • Application: 1995.5-2023 Toyota Tacoma (uses one pair, or two Bed Tie Down Anchors)
      • Early 2nd Gen Tacoma will require holes to be drilled
    • Application: 1999-2023 Ford F-250 (uses two pairs, or four Bed Tie Down Anchors)
    • Machined 6061-T6, anodized, engraved with logo and torque spec
    • Includes corrosion resistant, Grade 8.8 mounting hardware
    • Replaces stock steel tie-down points that are prone to scratching and rusting
    • Multiple methods for attaching ratchet straps, bungee cords, or rope
    • Radius on inside to avoid cutting straps and ropes
    • Center slot retains tie down straps
    • T40 Torx bit required to remove the stock bolts
    • M6 Hex bit required to install the new hardware
    • Designed and Manufactured in the USA
    • Patent Pending
    These have more options for attaching straps while being 1” closer to the factory bed rail. They will also clear tonneau covers and bed racks when the OEM tie-downs won't. These are MUCH STRONGER than the stock plastic cleats that flex and move under load.
    Sold in pairs
    • Fits 2005-2024 Toyota Tacoma w/ OEM Bed Rails
    • Replaces stock bulky, plastic or cast aluminum tie-downs
    • Lower profile design with more open area to attach straps
    • Flush design fits with tonneau covers and camper shells
    • Patent Pending
    • Everything you need for your Tacoma in one easy kit!
    • Save by ordering the kit!
    • Includes:
      • One pair of Bed Tie Downs
      • Two pairs of Rail Tie Downs
      • Free Shipping
  2. May 24, 2023 at 1:01 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I need to get something going on my ‘05, any detail on how you’ve done them with some drilling? Did you use a backing plate?
  3. May 25, 2023 at 6:30 AM
    Charvonia Design
    Keith
    Huntersville, NC
    I did it on my '06, it was super easy. I just drilled two 5/16" holes and used a fender washer and lock nut installed through the rear wheel well. I thought I might have to remove the fender liner but it pulled back and I had easy access.
  4. May 25, 2023 at 7:04 AM
    daveeasa
    David
    PNW
    I would personally be stoked if you had a photo of the location and backside somewhere?
    I have some D rings with backing plates in my '16 up front down low but I wasn't sure if I wanted to try to match the up high position or the down low position on the '05.
  5. May 25, 2023 at 11:27 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Sure thing! I moved mine back a bit to clear the gas cans, but the height is the same as a later 2nd Gen that came with the factory tie downs.
    daveeasa[QUOTED] likes this.
  6. May 25, 2023 at 11:39 AM
    daveeasa
    David
    PNW
    Thanks, looks awesome. That's where my D rings are on the '16. Did you consider up high where the later model OEM ones mount? I guess that's superfluous to you b/c you have the rails decorated. My rails are almost all blocked by a bakflip, part of the dilemma. Much harder/riskier to drill up high and maybe not really accessible.
  7. May 25, 2023 at 11:58 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Exactly, I already had Tie Downs up high on the rails, so I wanted to mount the Bed Tie Downs down low.
    Doesn’t Bakflip make brackets to relocate the rails lower so they’re usable? That might be another brand, I don’t remember.
  8. May 25, 2023 at 12:41 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    In for a set. Got any pics of the black powder coat? The ano looks great but doesn't last long in AZ.
  9. May 27, 2023 at 10:04 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Sure, here are some pics! I still need to add them to my site.
  10. May 27, 2023 at 10:06 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Dude those look awesome. Definitely in :thumbsup:
  11. May 27, 2023 at 10:11 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Thanks man, love your truck too. I actually used to live in AZ and I worked for Speedhunters from 2012-2018.
    drizzoh[QUOTED] likes this.
  12. May 27, 2023 at 1:24 PM
    tacoob21
    tacoob21 New Member
    2023 Tacoma TRD OR 4x4
    Just placed an order last night. Been waiting for sale/GB lol
    Charvonia Design[OP] likes this.
  13. May 27, 2023 at 2:59 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Thanks d00d! I appreciate that! I was wondering if that's where the username was from. I don't blame you for moving, especially if you went somewhere with seasons :rofl:
  14. May 28, 2023 at 8:55 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Group Buy canceled, changed it to a straight discount. Get them now, they won’t be priced this low again.
    drizzoh and tacoob21 like this.
  15. May 29, 2023 at 5:07 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Just placed my order. :woot:
  16. May 31, 2023 at 4:57 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Last day for this sale! Thanks for all the orders!
  17. May 31, 2023 at 7:09 AM
    jrgrieve
    jrgrieve Well-Known Member
    Justin
    2022 Tacoma SR
    Order placed! Looking forward to getting them installed.
  18. Jun 1, 2023 at 11:05 AM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    I missed it! If you wanna extend the sale one day, PM me a code I’ll order a full set right now.
