Billies 5100 1.75 lift very happy
Discussion in 'Suspension' started by superbikedad, Nov 29, 2009.
  1. Nov 29, 2009 at 12:44 PM
    superbikedad
    superbikedad [OP] Active Member
    Jeff
    Lake Stevens, Washington
    07 sr5 trd dbl cb 4x4
    Bilstein 5100's, 1.75 lift front, 1' block rear,265/70/16
    Finally did it. Installed Bilstien 5100's in all for corners.
    Set the fronts to 1.75 and installed 1" block in the rear
    on stock springs no tsb because truck is out of warranty.
    Tires are 265/70/16. Drives great.
  2. Nov 29, 2009 at 1:06 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    looks good
  3. Nov 30, 2009 at 3:25 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    Does look great! Did you have any issues with alignment? I just installed the 5100s set to 1.75 and they say they can't get the caster back. Weird too that they got it for the right side but can't get it on the left, so it pulls left (suck!)
    again, looks great.
  4. Nov 30, 2009 at 4:50 PM
    superbikedad
    Jeff
    I just installed the lift over the holiday weekend. Truck goes in Saturday for alignment. It drives pretty good now so hoping not to have any issues.
    I will post if there is an alignment problem. Hopefully you can get yours figured out.
  5. Nov 30, 2009 at 5:14 PM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Looks good. I'm wanting to go 1.75" with 265/75/16's when the factory BFG's wear out.
  6. Nov 30, 2009 at 5:35 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    I'd really love to find out how that goes. I'm not sure whether I've taken it to the wrong shop or if it really is a problem. It's frustrating. Worst part is that mine drove fine before they aligned it, now it drives like poop. Please let me know how it goes!!
    cheers
  7. Nov 30, 2009 at 5:50 PM
    c-slak
    c-slak Well-Known Member
    Chandler, AZ
    08 TRD Offroad 4x4
    5100's all around, 265/75/16 BFG ATKO's on MB Razor's, short shift, clutch mod, tsb springs, tsb aal
    Go to a different alignment shop or go back and have them do it again. I got mine pretty close to ideal with 5100s at 1.75 with toytec 1/4" top plate spacers. Camber is close to 0* and caster is at 2.3/ 2.4. It took me going back and complaining a few times for them to put in the work to get it in spec. The first time the tec came up and started defending his work saying it was "in spec" according to the computer.
    Give them the exact alignment numbers you want or they will tend to do a "good enough" alignment. Then if you ask for them to hook it back up to the alignment rack they will tend to defend their work saying it is the lifts fault. Been through it at 3 different Firestones with the "lifetime alignment". Found a good shop and they will be the only ones doing it from now on.
  8. Nov 30, 2009 at 5:51 PM
    superbikedad
    Jeff
    Thanks. Yeah I want to go with a more aggressive look when I need new tires. But happy for now.:)
  9. Nov 30, 2009 at 5:52 PM
    superbikedad
    Jeff
    Hey thanks Mikey D. :D
  10. Nov 30, 2009 at 5:56 PM
    superbikedad
    Jeff
    Yeah I agree with C-SLAK. I'd gp somewhere else. Seems like guys on here can get their trucks to align pretty well. I for sure will post after my alignment and let you know.
  11. Nov 30, 2009 at 5:58 PM
    c-slak
    Chandler, AZ
    08 TRD Offroad 4x4
    Looks good btw. Forgot to mention that in original post!
  12. Nov 30, 2009 at 6:01 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Looks great bud, congrats!
  13. Nov 30, 2009 at 7:53 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    Thanks a ton! I'm gonna go to another guy and see what happens. I feel like it ought to go--it's not that big of a lift. Thanks for the input, and any other is welcome. Superbikedad--I'm interested to hear how it goes with you!cheers all.
  14. Nov 30, 2009 at 8:41 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    Hey by the way--I know I'm an idiot for having to ask this question, but I read that there is a difference in the springs between the R and L sides, which is which? I have a pink paint mark on one and a blue/gray paint mark on the other and I'm guessing this is what indicates which side is which, but I've gotten confused and don't know where they're supposed to be. Any help?
