Billies at 2.5 - good alignment achieved
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hakabo, Mar 27, 2013.
  1. Mar 28, 2013 at 3:04 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    0 camber and toe are optimal but not the caster. The caster is the angle that keeps your vehicle tracking straight without using the wheel. Less caster will make the vehicle want to wander around.
  2. Mar 28, 2013 at 3:08 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    It does.
    To be honest, I need to see if I can find the most recent alignment sheet (it was a year ago) because I MIGHT be wrong on the 2.0 number. I will say at 2.5" lift it was NOT comfortable to drive. I didn't even want my gf driving it because I felt it was somewhat dangerous.
  3. Mar 28, 2013 at 3:09 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    This is incorrect. Mine was at 0 toe. You are absolutely wrong.
  4. Mar 28, 2013 at 3:19 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    as much as you explain caster to me, i understand its importance, but still cant visualize it in regards to the tire. Whenever I do the alignment on my atv I am looking at toe and caster angles, as well as steer strait angle. My methods involve alot of measuring with a tape and comparing sides but never had to deal with camber. I guess this is why I can't visualize it.
    I actually set my atv with alot of negative caster i guess (bottom of the wheels kicked out) The book calls for it to be pretty much neutral but it seems to handle better in the sand with it set up like this.
  5. Mar 28, 2013 at 3:23 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
  6. Mar 28, 2013 at 3:52 PM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
  7. Mar 28, 2013 at 3:56 PM
    ntilehman
    Seth
    Charlotte, NC
    Camber is what leans yours wheels in or out at the top. Caster is the relationship between the upper and lower pivot points(ball joints). Upper behind the lower is Pos caster.
  8. Mar 28, 2013 at 4:07 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yes, everything as close to zero as possible except caster.
    According to my alignment sheet, caster is between 1.4 and 2.9
    But I have seen different numbers everywhere.
    Mine is set to 2.8
    You will want to max it out with a lift and bigger tires for more stability. You are probably fine tho, I just don't like your camber.
  9. Mar 28, 2013 at 4:21 PM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    my camber is .6 and .7...
    I feel kinda bad, this isn't my thread. I may have hijaked a bit :D.
  10. Mar 28, 2013 at 5:47 PM
    hakabo
    hakabo [OP] Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    so can i just go back and see if they can adjust it to the specs i want? i def dont want to pay another $70 for it. on the fence on lowering back to 1.75 too, it is a little stiff in the front, but i may get used to it. the main reason i want the full height (aside from the obvious badass-ness of it) is to eventually run 255/85/16s.
    also, if i just lower it back to 1.75, would that improve all the numbers w/out another alignment just due to the lower angle?
  11. Mar 28, 2013 at 6:34 PM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    You would definitely need another alignment.
