Billies-Eibachs-TSB yada-yada-yada
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nick54, Jan 28, 2011.
  1. Jan 28, 2011 at 9:21 PM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Ok sanity check - I have the TSB rear spring packs installed, I have 5100s for the front and back and am now thinking about eibach coils for the front. The billies and coils are yet to be installed. Question is what setting on 5100s in combination with the coils will level with the back end?
    EDITED
    I would like to hear from some with 2010 TRD Sport DC, TSB rear Springs, Eibachs and Bilstein 5100s. What have you set the billies at and what is the resulting front to rear attitude?
    These are my current measurements: the drivers side rear is 38.25" from the ground to the point on the fender vertical throught the center of the wheel and the drivers side front is 34.75" using the same reference points.
  2. Jan 28, 2011 at 9:25 PM
    dmz1241
    dmz1241 Well-Known Member
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Bilstein 5100's all around, Eibach coils, 2" shackles, Flowmaster 60 Series
    i think most people leave the 5100s set at zero when they have eibachs. you are putting to much presure on the coils if you go much higher than the zero setting. I have 5100s and eibachs and i left them at zero.
  3. Jan 28, 2011 at 9:28 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Take some measurements as it sits now and you'll have your answer. No way to tell otherwise.
  4. Jan 28, 2011 at 9:33 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    .85 is ok, I think that would make you level. Set at 0 would be a smoother ride and a slight front rake
  5. Jan 28, 2011 at 9:35 PM
    rraether
    rraether Well-Known Member
    Albuquerque
    07 tacoma 4x4 sport access cab
    debagged, windows tinted, custom NM trd sport decals, AEM bruteforce cold air intake, 13" wicked flow muffler, fox 2.5 DSC coilovers, all pro off road UCA's, fox 2.0 smoothies in rear with all pro off road expedition leaf springs, besttop softopper, first prototype of white clouds hybrid sliders!!
    i have the billies and the eibachs unistalled as well. I am planning on going with the .85 on the billies but since i am doing that i will definitely need new UCAs. but i hear the ride is awesome. Most people leave it at zero to level it out.
  6. Jan 28, 2011 at 9:44 PM
    Nick54
    Nick
    Mentor Ohio
    I thought I read that greater than 1.75 would require UCA replacement, have I missed something?
  7. Jan 28, 2011 at 9:50 PM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Greater than 1.75 MAY need UCA's. There are tons of people running 2.5" on stock UCA's with no issues. Just like the question as to what setting you should run to be level, every truck is different.
  8. Jan 29, 2011 at 7:06 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I have my 5100's set at .85 with the ebiach's. With the TSB in the rear of the truck, the truck will sit almost level with nothing in the bed (bed will be slightly higher).
    After you drive it for a couple of weeks or so or put a load in the bed, it will be almost perfectly level.
    I think overall, I got about 1.5 in lift in the front.
    Then you put on 265-75-16 tires and you get an additional amt. of lift.
    My truck sits perfect for what I use it for...hunting, fishing, towing my boat and my jeep. Oh yea, going back and forth to work.:)
    By the way, my truck is an access cab 4x4 SR5.
  9. Jan 29, 2011 at 11:25 AM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    i am gettin ready to do this setup. i'm puttin on the eibachs and leaving the 5100s at 0 with the rear tsb. that should have a slight rake left. on my last tacoma i had 5100s at 1.75 with rear tsb and i hated putting a load in the back and it always being nose high. i wnat a little rake so i can have a slight load and no more nose high.
  10. Jan 29, 2011 at 11:30 AM
    YoterHead
    YoterHead Well-Known Member
    Are the Eibachs comparable to the sport springs (linear) or the OR springs (progressive)?
  11. Jan 29, 2011 at 9:34 PM
    Bodete
    Bodete Well-Known Member
    Missouri
    2009 SR5 DC LB 4x4
    Eibach springs w/ 5100 Bilstein shocks set to "0", Rear TSB
    I have 5100's set to 0 with eibach springs. I also had the rear tsb done. This will give you a slight rake, making the rear end a little higher than the front. The ride is great.
  12. Jan 30, 2011 at 10:28 AM
    Nick54
    Nick
    Mentor Ohio
  13. Jan 30, 2011 at 10:49 AM
    creeper
    creeper Well-Known Member
    Since you're bumping this thread, I'm going to assume you have done your homework now and taken measurements of your truck. What are they?
  14. Jan 30, 2011 at 11:11 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    A picture is worth a thousand words. TSB, Eibach's, 5100's at "0"
    Ride is perfect for me, mostly used as a daily driver, some mild off roading to get to fishing spots.
  15. Jan 30, 2011 at 1:54 PM
    Nick54
    Nick
    Mentor Ohio
    Ok here goes, using the center of the wheel as the vertical index the drivers side rear is 38.25" from the ground to the point on the fender vertical throught the center of the wheel and the drivers side front is 34.75" using the same reference points. Those are the only measurements I took however if you think I should have the passenger side measurements I will get them.
  16. Feb 5, 2011 at 5:10 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    Bump!! Have you done anything yet? I'm wanting to do the same thing. I have the TSB done in the rear and have ordered the 5100s for both the front and rear. I am considering ordering the coils as well. Would like to hear some more input.
  17. Feb 5, 2011 at 6:01 PM
    Nick54
    Nick
    Mentor Ohio
    I have the Bilsteins in possession, the Eibach's and Light Racing UCA's should be in the mail. Not sure exactly when I will get to the install as here in NE Ohio the weather sucks. My garage is a woodworking shop so maybe my friend Dan will let me use his garage.
  18. Feb 5, 2011 at 6:51 PM
    B_brand
    Brandon
    Oklahoma
    I'm not planning on changing the UCAs. Is this something I should consider?
  19. Feb 6, 2011 at 7:22 PM
    Nick54
    Nick
    Mentor Ohio
    I think it really depends on how high you intend to lift the front. If you lift it high enough you won't be able to get you alignment into specs without changing the UCA's.
