Billstein 5100 easy install method
Discussion in 'Suspension' started by Holyfather, Mar 24, 2012.
  1. May 23, 2012 at 5:17 PM
    #41
    Uplander
    Uplander Active Member
    Idaho
    2012 Barcelona Red DCLB Sport
    TRD Supercharger, URD 2.825" Pulley, TRD Exhaust, Moroso Catch Can, MB Chaos Wheels, 265/65/17 Hankook Dynapro's, 5100's @ .85", ARE MX Topper W/BedRug
    Just put on my 5100's set at .85". This video really helped me out and it was completely safe and easy to do. At no time was there any chance of having the spring fly off. Thanks!
  2. May 25, 2012 at 6:20 PM
    #42
    ManMan
    ManMan Well-Known Member
    I'll be trying this out tomorrow. Having had a spring slip off one of those crappy dual screw compressors, I was not looking forward to using one again!
  3. May 26, 2012 at 3:25 PM
    #43
    bunsojr
    bunsojr Well-Known Member
    Northern California
    2005 Silver DCLB
    Bilstein 5100s with OME 885 Medium Duty Dakar Leaf Springs SPC Upper Control Arms Pro Comp 7032 wheels BFG AT K02 in 275/70/17
    would our stock jack be sufficient to use for this method?
  4. May 26, 2012 at 8:01 PM
    #44
    Holyfather
    Holyfather [OP] Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
    It might but i suspect that the stock jack might not go high enough ...
  5. May 26, 2012 at 10:32 PM
    #45
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    No, please don't try it. You should really use a floor jack.
    A lot of people think this method is unsafe. I made the video and I think it is safe if you follow the instructions. But using the stock jack (which is a screw type, not hydraulic) may not work and could cause injury. A floor jack is much more stable because it has a much greater surface area on the floor and on the LCA.
  6. May 26, 2012 at 10:41 PM
    #46
    livel0veryde
    livel0veryde Well-Known Member
    josh
    missouri
    Tacoma based buggy
    this is how i did mine..pretty easy install
  7. May 27, 2012 at 10:16 AM
    #47
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Bite the bullet and buy a good floor jack. It's one of the best tools I ever invested in. I have two of them. You will use it over and over again if you like to do your own work. I can't imagine being without one.
  8. Jun 3, 2012 at 11:10 AM
    #48
    Stockmonester
    Stockmonester Well-Known Member
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    in channel vent visors
    when i jack up on the lca to compress the spring the whole side of the truck lifts up and doesn't look like the spring is compressing, the top nut on the shock doesnt look like it is moving. Am i doing it right or am i missing something?
  9. Jun 3, 2012 at 12:59 PM
    #49
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    2013 Trd Sport
    plenty
    Sweet I wish I saw the Video before I did mine. All it cost me was 2 cold packs of beer to use my friends wall mounted spring compressor but the OP's method looks super safe and easy.
  10. Jun 4, 2012 at 11:34 AM
    #50
    BTO
    California
    You are not understanding the concept behind this method. You are not supposed to compress the spring. This method is about slowly releasing the spring tension it already has.
    You jack up the truck (on the frame) till the wheels are off the ground and put on jackstands. Then you put the jack under the LCA to support it (it's being pushed down by the spring). Only jack the LCA a slight amount and then remove the two LCA bolts by the ball joint. You then slowly let the jack down which slowly releases the spring tension.
    MidgetTosserr and lo2hi like this.
  11. Jun 4, 2012 at 2:18 PM
    #51
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    That's what i did, the video shows the complete shock moving up that's what got me confused. So i was doing it right then just wanted to double check
  12. Jun 4, 2012 at 4:35 PM
    #52
    Holyfather
    Arizona
    2011 TX Pro TRD
    When I did mine it did that too. If you can get it up enough to get some of the threads through the top you can just tighten the nut to get it the rest of the way.
  13. Jun 6, 2012 at 6:43 PM
    #53
    jerlane
    jerlane Well-Known Member
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    I just posted a question on the original thread, but there seems to be more activity here... Are people all using a torque wrench when putting everything back together or just cranking everything tight by hand or with an impact wrench. Can anyone clarify what and where to mark the spindle? When loosening the LCA?
    Thanks!
  14. Jun 6, 2012 at 7:14 PM
    #54
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    I installed the 5100's today using this method and everthing went great. Thanks guys.
  15. Jun 6, 2012 at 7:19 PM
    #55
    Holyfather
    Arizona
    2011 TX Pro TRD
    I just cranked them down. Haven't had any problems with things coming loose but others might insist on using a torque wrench. Mine was premarked with yellow paint so I didn't have to mark mine. Also things lined right back up when I put it back together
  16. Jun 7, 2012 at 11:46 AM
    #56
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    I anstalled my 5100's yesterday and took my truck in for an alignment today and they said they didn't know if they can get the camber down that much or not. What should I do?
  17. Jun 7, 2012 at 3:49 PM
    #57
    Stockmonester
    Nick
    Rome, Ny
    2019 v6 sr 4x4
    so im taking my front end apart loosening the top nut on the shock and its to the point where i cant hold the top of the shock from spinning can someone give me some insight? and yes im a noob at this
  18. Jun 7, 2012 at 6:34 PM
    #58
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    If you don't plan on re-using the old shock you could cut the plastic and hold the shock with a pair of pliers
  19. Jun 23, 2012 at 9:43 AM
    #59
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    I used needle nose vise grips and held by the top. Once the nut is backed off too far to fold it this way, move the vise grips below the nut and clamp them on the threads.
  20. Jun 23, 2012 at 1:22 PM
    #60
    cro
    cro Member
    Nor Cal
    sport 4x4 trd
    Hi all long time reader and first time poster. I finally installed 5100 on my truck yesterday using the method in the video. eg no spring compressor.
    I got a quote to have toyota do it and I said no way to $550 for just the fronts.
    At no time did I feel this method was dangerous at all. slowly lowering the LCA to take the pressure of the spring is very easy and a great way to do it.
    A couple of tips I would suggest though
    1. dont try and do this without moving the sway bar out of the way it makes life so much easier if you do.
    2. I tried the push the LCA down without loosening the adjustment bolts but found it impossible to get enough room to put the strut back in. I did however only loosen the rear adjustment bolt after marking them correctly.
    Thanks for the video and tips it made life much easier and cheaper.
