Billstein 5100 easy install method
Discussion in 'Suspension' started by Holyfather, Mar 24, 2012.
  1. Jun 28, 2012 at 12:35 PM
    #61
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    X2
    Anyone?
  2. Jun 28, 2012 at 12:45 PM
    #62
    Holyfather
    Holyfather [OP] Well-Known Member
    Arizona
    2011 TX Pro TRD
    Front Bilstein 5100s @ 1.75"
    Not me. I used my stock springs
  3. Jun 28, 2012 at 3:52 PM
    #63
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Should work just the same as stock springs. I don't see why it would matter what springs you use.
  4. Jun 28, 2012 at 3:58 PM
    #64
    BTO
    California
    I had no problem with the sway bar getting in the way. I did not remove the springs. They stayed stuck up in the shock tower while the shocks dropped out from inside them. Maybe that's why.
  5. Jun 28, 2012 at 4:16 PM
    #65
    MADtaco09
    MADtaco09 Hawaii, Fuck Yeah!
    Pahoa, Big Island.
    Barcelona Red TRD Sports
    6" Basic Fabtech Lift Kit. 2012 Off Road Tacoma Struts (Less than 100 miles). Cab Mount Chop. K&N CAI. Borla Exhaust. BHLM w/Custom Yellow Blinker Lens & Yellow Reflector. Black LED Altezza Tail lights. Black LED Bermuda 3rd Brake Light. Yellow Tinted Fogs w/ HID 35w 3000K. Nokya Hyper Yellow DTRL Bulb. Anytime Running Fog Light Mod. DTRL Switch Mod (Stealth Mode). Hyper White LED Dome & MAP Lights. Nokya Hyper Yellow Parking Lights. 20% Tinted Windows. Viper Alarm with Remote start. Blacked Out Valance. Blacked Out Badges. Blacked Out Radiator. Relocated Horns. OEM Roof Racks. Wet Okole Seat covers. SATOSHI Grille w/ FJ 60 TOYOTA Emblem Color Matched. TRD License Plate Frame. Sleepy Eyelids Color Matched. 13" EuroStyle Antenna. Bi-xenon Morimoto Mini Stage III Kit (D2S) Retrofit w/ Morimoto 3Five 5000K Bulbs. SS Extended Brake Lines. Seat Belt Chime OFF. Wish List: N-Fab Steps. DTLT Headers. 4.88 Gears. Alcan Leaf Springs. One Piece Drive Shaft.
  6. Jun 28, 2012 at 4:36 PM
    #66
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    I didn't have any trouble with the sway bar either, and I did remove the springs.
  7. Jun 28, 2012 at 5:29 PM
    #67
    greenrustic
    NY
    I just found out that at the high school down the road where my buddy works they have a Branick 7400 spring compressor that I can use so I will probably just go that way.
  8. Jun 30, 2012 at 10:09 AM
    #68
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I just finished doing all 4 corners along with a tire rotation using this method. I also added the driver side front spacer to even everything out. I had it on the 0.85" position. Took about 2 hours total.
    I still have the original tires at 43k miles, so I will be replacing them soon. I am going to let everything settle a bit and see if I can see any gross issues. On the test run immediately afterwards, it tracked straight and the steering wheel was on-center. I will see how the tire wear looks and how the mileage looks and evaluate whether I need to get tires sooner than later. I don't want to pay for an alignment on those old tires just to do it again soon. I may take a couple swings at it myself, but we will see.
  9. Jun 30, 2012 at 10:42 AM
    #69
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Anytime you do suspension work you have to get an alignment. New tires don't affect your alignment. Get your alignment done now. Get tires whenever you need them.
  10. Jun 30, 2012 at 10:54 AM
    #70
    Holyfather
    Arizona
    2011 TX Pro TRD
    X2. Mine tracked straight afterward but my toe in was way off. 0.63 degrees on either side
  11. Jul 11, 2012 at 5:49 PM
    #71
    ccurtis0805
    ccurtis0805 Well-Known Member
    cale
    South Florida
    2010 SR5 4x4
    5100s all around, rear tsb, interior LEDs (center console, driver & passenger side floor boards, glove box, under a/c controls, rear cupholders; BHLM; DIY Satoshi
    Is this method only for coil overs?
    And, has anyone used the jack that comes with the truck?
  12. Jul 11, 2012 at 7:47 PM
    #72
    Ostrichsak
    Jer
    Do not even THINK about using the jack that comes with the truck. Sometimes when you try to save a little money you need to spend money for good equipment and tools to do so. Using the stock jack will likely cause you to end up with more damages or injuries (or worse) than what you would have saved paying a shop to do it for you. The factory jack is for emergencies ONLY and is barely even capable of working in those situations. If you can't afford a decent floor jack (hell, Harbor Freight has decent ones for WELL under $100) & jack stands then you shouldn't be doing this mod anyway. If you're capable of taking on a task such as this then you're capable of taking on many others and most all of them will require you using your newly purchased jack and stands. Some things aren't worth cutting corners on and what you're talking about is not only incredibly dangerous it's dangerous in a manner that could cause substantial damages to your truck, your garage, your driveway and most of all... you. People have died doing what you're asking about so I suggest you heed this warning and take it serious because you're life could depend on it.
    I keep seeing people ask about this for this procedure and I don't get why people would even consider this. This is the same as putting the emergency donut on your car and then trying to go on a Canon Ball Run across the nation at top speed. That's not what the object was engineered for and trying to use objects so far out of their design intent could be deadly.
  13. Jul 12, 2012 at 4:07 AM
    #73
    ccurtis0805
    cale
    South Florida
    2010 SR5 4x4
    @Ostrichsak, Thanks for the slap on the wrist, mom. lol. I get it, I will go out and buy a floor jack. Any suggestions on a floor jack?
    I actualy bought a Torin floor jack yesterday before asking the question. But, when I got home and took it out of the box I noticed what a real POS it actually was and took it right back. The jack handle was so sloppy in the handle reciever that you lost probably 6-10 inches in down/up travel. I read a similar review on a craftsman having sloppy down/up travel. Is this the norm with jacks under $150?
  14. Jul 12, 2012 at 5:06 AM
    #74
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Sub'd. This works the same on a first gen, right?
  15. Jul 12, 2012 at 5:43 AM
    #75
    greenrustic
    NY
    I've had a craftsman for 15 years and its been great.
  16. Jul 12, 2012 at 5:45 AM
    #76
    greenrustic
    NY
    Anyone have a comprehensive list of the tools needed including socket sizes to do this?
  17. Jul 12, 2012 at 10:07 AM
    #77
    ccurtis0805
    cale
    South Florida
    2010 SR5 4x4
    Saw some good reviews on TW about the Arcan jack from costco. Went their today and picked one up for $105. Thanks.
  18. Jul 12, 2012 at 1:05 PM
    #78
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I just added some notes to the video.
    Added Torque Specs and some notes regarding removing the sway bar.
    Torque Specs:
    Shock to LCA: 61 ft./lbs.
    Shock shaft to Top Plate: 20 ft./lbs.
    Steering Knuckle to Lower Ball Joint Attachment: 118 ft./lbs.
    LCA to Alignment Cams on Crossmember: 100 ft./lbs.
    Tools Needed:
    Floor jack and at least 2 Jack Stands
    3/4" (or 19 mm) socket and end wrench for Lower Ball joint attachment bolts, nut from top of shock shaft and LCA alignment cam bolts.
    17mm end wrench or socket to remove sway bar link nuts
    6mm Allen Wrench to hold sway bar link shaft
    Torque Wrench
    Small Crescent Wrench (open ended adjustable wrench) to hold top of shock shaft from spinning
    1 Green, Sharpie brand, felt tip marker to mark the alignment cams. (color and brand can be changed at your discretion)
  19. Jul 12, 2012 at 1:33 PM
    #79
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    I'm assuming these torque specs are for a 2nd gen right? I'm guessing they will be fairly close to the same as 1st gens. And that video should be the same for a 1st gen right?
  20. Jul 12, 2012 at 1:48 PM
    #80
    DDD
    Derek
    Santa Clarita, CA
    These specs are for the 2nd gen. Probably not the same for 1st gen. The video was made for 2nd gen. I have never done it on a 1st gen. Sorry.
