Billstein 5100 easy install method
Discussion in 'Suspension' started by Holyfather, Mar 24, 2012.
  1. Jan 15, 2013 at 2:07 PM
    #101
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    how hard is it to align the alignment cams back up after? they just slide right back in? just want to know everything before hand.
  2. Jan 15, 2013 at 3:10 PM
    #102
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    You don't remove them. They rotate. When you loosen the bolt And move the LCA they may rotate. When you are done just rotate them back to the marks you left. One side of each cam has a place for a wrench to help turn the cam.
  3. Jan 15, 2013 at 4:42 PM
    #103
    TwzteD
    Kyle
    St Lucie Fl
    gotcha thanks for your help.
  4. Feb 2, 2013 at 6:12 AM
    #104
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    Trying to remove top shaft bolt and the rod it is on which runs through the shock is just turning with it. What do I do?
  5. Feb 2, 2013 at 10:14 AM
    #105
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    There's no hole in the shaft for an Allen wrench on my 2013 Double cab.
  6. Feb 4, 2013 at 2:58 PM
    #106
    dtopgun515
    Darrell
    Hey Yall Georgia
    13 TRD Sport
  7. Feb 26, 2013 at 9:05 PM
    #107
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Did this today and it worked like a champ. About 1 1/2 hours and I was done. Thanks for the Video!!!
  8. Mar 18, 2013 at 7:54 AM
    #108
    duffman825
    duffman825 Master Novice
    Mark
    Boise Idaho
    06 DCSB Off Road SuperWhite
    Billies in the front with Toytec 2.5 coils, Camburg UCAs, Add-a-leaf, Rear Billies, Clutch Noise TSB, Blower Fan TSB, Sway bar delete, Tint the front to match, Homer-oshi grill, BHLM, GTA car kit, AFE Magnum Force Stage 2 CAI, SCS SR8 wheels, 285/75/16 Duratracs, TRD quick shifter
    Thanks for the video! Used it last weekend to install some 5100's. Came out great.
  9. Jun 6, 2013 at 1:28 PM
    #109
    bwanamukubwa
    bwanamukubwa Well-Known Member
    Tennessee
    Thank you very much for your video. Do you know if these torque values are the same for all 2nd gens? I have a 2010 and just wanted to cover all the bases before doing this. Thanks.
  10. Jun 7, 2013 at 9:47 AM
    #110
    DDD
    Derek
    Santa Clarita, CA
    These are the same for all second gen. 6 lug.
    So you will be fine.
  11. Jun 10, 2013 at 5:06 PM
    #111
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Thanks again, DDD. Used your you-tube for the second time yesterday. Now have 5100s installed.
  12. Jun 10, 2013 at 9:32 PM
    #112
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
    Planning my install of 5100s this weekend was a little worried about it since I am not a wrnecher...I have a friend who is helping out and with all the info and the video it seems like we will be fine...thanks ddd for the write up and the updating of the video and this thread with the torque specs and to everyone else that has tried this and reported back positively...
  13. Jun 12, 2013 at 7:24 AM
    #113
    bwanamukubwa
    Tennessee
    I installed 5100's all around last weekend and didn't have to remove the sway bar. Took me longer than necessary because removing the top nut on the old shock was a pain.
  14. Jul 14, 2013 at 9:59 AM
    #114
    StrikeEagle
    StrikeEagle New Member
    Georgia
    07 PreRunner
    I've been reading this forum for a while, but had to chime in on this way of changing front coil overs. I just finished my fourth swap (2nd truck) and this is BY FAR much easier than screwing around with my spring compressor. 1 1/2 hours from wheels up to wheels down. Never felt any danger during the process, unlike using compressors. Great thread!
  15. Jul 27, 2013 at 10:09 AM
    #115
    WhiteTacoma09
    WhiteTacoma09 Well-Known Member
    Curt
    Florida
    09 Prerunner access cab
    ZXE Headlights Drop in k&n filter Kobalt slim toolbox Tinted 17" FJ trail edition wheels OEM foglights 265/70/17 BFGs AVS vent visors Pioneer AVH-X1500DVD
    Video looks great, but where is your sway bar? Maybe I just don't see it. For me, it was in the way when installing the longer strut assembly, thanks.
  16. Jul 27, 2013 at 10:13 AM
    #116
    WhiteTacoma09
    Curt
    Florida
    Saw the above info, so just the sway bar linkage was removed? The part that you hold the center with an allen key or the entire sway bar itself gets removed.?
  17. Jul 27, 2013 at 11:29 AM
    #117
    DDD
    Derek
    Santa Clarita, CA
    I completely removed the sway bar.
    But other people have done it by just disconnecting the links.
  18. Jul 28, 2013 at 4:44 AM
    #118
    StrikeEagle
    Georgia
    07 PreRunner
    I just did another Taco since my last post and didn't have to do anything with the sway bar either time. They slid down and away from the bar on both an 07 and an 09.
  19. Aug 15, 2013 at 7:06 AM
    #119
    Mtroserider
    Mtroserider New Member
    Going for it this morning. The guys at Les Shwab tried to talk me out of doing this and bringing the struts into them after I removed them from the truck. This looks way easier. They'll be surprised when I walk in this morning "alive" to get an alignment. Thanks for all the info.
  20. Aug 15, 2013 at 2:49 PM
    #120
    Mtroserider
    Done! Finished it in a little more then an hour and that included making a cup of coffee in the middle of it. Did not touch the sway bar linkage at all and found that if you loosen the LCA to frame "just a little" your alignment does not move or very little if any. This is the only way to change out struts on these trucks. Walked into Les Shwab for an alignment and got the :eek: when I told them I did the struts without a compressor. Still alive!
