Billstein 6112 2" lift: run at max clip setting or use spacers?
Discussion in 'Suspension' started by GawainXR, Sep 6, 2024.
  1. Sep 6, 2024 at 7:18 AM
    GawainXR
    GawainXR [OP] Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    Greetings,
    I'm going to need approx 2" of lift to keep my front end in spec with my rear AALs with the overload left in.
    Would there be any negatives to using 1/4 thick spacers (~3/8 lift) and running the clips at 7/9 opposed to 9/11 for a bit additional travel?
    Here's the spacers I have planned.
  2. Sep 6, 2024 at 7:28 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Besides the potential to overtravel and damage your CV or bottom out the shock before you hit bumpstops? Bilstein built the 6112 as a pretty high performance shock, I'd let it be unless you know exactly what you're doing.
  3. Sep 9, 2024 at 6:26 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    1/4" spacer wont hurt anything. But I wouldn't go more.
  4. Sep 9, 2024 at 7:42 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    I'm going to likely do 8/6 plus the spacers for approx 1.4" of lift.
    If things work out right that should give me somewhere from 1/2 to 3/4" of rake when I add 2" of lift to my currently sagging rear.
