Billstein .85 cv joint problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by magnum922, Feb 11, 2012.
  1. Feb 11, 2012 at 4:32 PM
    magnum922
    magnum922 [OP] Well-Known Member
    2011 DCLB 4.0 tow pkg 4x4
    If you have front billsteins set at .85 will you still have problems wearing out your cv joints? I know 1.75 you will.
  2. Feb 11, 2012 at 4:41 PM
    TACWUT
    TACWUT Well-Known Member
    San Diego
    12 prerunner DC
    Flowmaster turndown, 5100 up front/5150 rear, maxtrac spindles, 2" tuff country add a leaf+TSB.
    I have it at. 85 and the angle seems good to me.
  3. Feb 11, 2012 at 4:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    At .85" you shouldn't have any problem.
    Alot of people are even running 1.75" with no issus, but then some have had problems.
    These trucks don't seem to like increased angles in the drive lines.
    But .85" doesn't change it much. I personally would not worry about it.
    at 1.75" I'd keep an eye on it and add a Diff drop kit if needed.
    Maybe others that have been running on .85" for a while will chime in.....
  4. Feb 11, 2012 at 5:01 PM
    floridaoccifer
    floridaoccifer Civil Servant
    Subbed on this one... :popcorn:
  5. Feb 11, 2012 at 5:29 PM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    I've got my billsteins set at 0.85 and have about 20000 on the truck since I put them on with no problems.
  6. Feb 11, 2012 at 5:30 PM
    acdronin
    acdronin Well-Known Member
    I'm at 1.75 for 15k and no problems here
  7. Feb 11, 2012 at 5:37 PM
    IslandBoy86
    IslandBoy86 Well-Known Member
    Las Vegas, NV
    What is the ideal angle of the cv axel?
  8. Feb 11, 2012 at 5:44 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    You should be pretty safe under 2", even at the 2.5. 3" is the grey zone, some have problems, some dont.
    Diff drops don't do anything on 2nd gens
  9. Feb 11, 2012 at 6:58 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
