billsteins and AAL
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacomapreerunner, Jan 12, 2010.
  1. Jan 12, 2010 at 2:05 PM
    07tacomapreerunner
    07tacomapreerunner [OP] Well-Known Member
    tacoma
    ok so i have the bilsteins 5100s set at 2.5 right now and them in the rear. i want to get an AAL because right now with about 500 pounds it is really sagging low. i was wondering how hard is it to install? also would i need a new U bracket? and what kind should i get and what hight ? thanks
  2. Jan 12, 2010 at 4:14 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I think you need a better description. sounds like you put the billys@2.5 in the rear??? There are plenty of threads about AALs , try different wording in the search option or look at the bottom of this thread under similar threads.
