Billstien 5100's to level the back end...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ahiaring, Nov 9, 2017.
  1. Nov 9, 2017 at 1:54 PM
    ahiaring
    ahiaring [OP] Member
    Adam
    2013 Red Tacoma SR5 4X4 SC SB 4.0
    2" Front Level
    I just purchased a New to Me 2013 4.0 Double Cab SB 4X4 SR5. Thing looked brand new and only had 46,500 miles on it, brand new 265/75 16 AT's at a price 2k under book. Couldn't say no.
    However, it came from the dealer with a what appears to me as 2-2.5" front level. If you look at the attached pic, it actually makes the front end appear a touch higher than the back - and I hate that, I want it at least level if not just a tiny rake from the back to front.
    Can I install bilstein 5100's with the settings adjusted to take care of this or am I going to have to add something else to the back end?
  2. Nov 9, 2017 at 1:54 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    Rear 5100s are not adjustable.
    Alexely999 likes this.
  3. Nov 9, 2017 at 1:57 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    You can use the 5100s. But you'll need something else to provide the lift.
    outlawtacoma likes this.
  4. Nov 9, 2017 at 2:00 PM
    ahiaring
    Adam
    2" Front Level
    My other thought was to just have it removed, realigned, and still do he 5100's for a better ride quality...
    poseytaco and blu92in99 like this.
  5. Nov 9, 2017 at 2:06 PM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Looks pretty level to me. :notsure:
  6. Nov 9, 2017 at 2:06 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    You could always do an add a leaf! Pretty simple install.
    dziner and blu92in99 like this.
  7. Nov 9, 2017 at 2:11 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Add a leaf or a 1” block.
  8. Nov 9, 2017 at 6:25 PM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2014 TRD O/R 4x4
    If it's a spacer lift, my vote would be to remove it. Do the new 5100s all around and level it with the front shocks to match the back. Most people say the .85 setting will do it. On my truck, setting the fronts to 0 was perfect.
  9. Nov 9, 2017 at 6:31 PM
    eon_blue
    Azusa, CA
    The rear is not lifted by shocks, it's lifted via the leaf springs. An add a leaf (AAL) will give you about an inch give or take, out swap out the stock leaf packs for new ones.
  10. Nov 9, 2017 at 6:39 PM
    KMFDM_V
    KMFDM_V Well-Known Member
    Ken
    Sacramento, CA
    09 Timberland Mica 2.7L 5MT 4x2 Access
    I may have tweaked a few things...
    If you want lift, raise the rear and use 5100s as others have said. If you don’t want lift though but would like it leveled you can get takeoffs from a 3rd gen Off Road. They will be cheaper than 5100s, not valved for lift applications like 5100s, and the 3rd gen coils on a 2nd gen will give ~1” up front to help level you.
  11. Nov 9, 2017 at 6:41 PM
    doorsidedown
    doorsidedown Well-Known Member
    HeadStrong 3 leaf progressive and you're done boss.
  12. Nov 9, 2017 at 6:56 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    Had a 2.5 level put in mine and had to add a 1 inch block to the back. The back now is about 1/4 inch higher which is better than it being nose high.
  13. Nov 10, 2017 at 7:39 AM
    dziner
    dziner Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    I have the Wheeler's progressive AAL and 5100's that I used originally on my 2014 TRD Off-road. But I have since upgraded to Bilstein 5160's and OME Dakar leaf pack since I have a cap, fridge, and lots of gear that I haul every day. The 5100's and AAL are sitting in my basement waiting for someone to buy them.
  14. Nov 10, 2017 at 7:48 AM
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    Get in touch with Headstrong , Marie knows her stuff and is very helpful , shell tell you exactly what you need to know/do.
  15. Jan 22, 2018 at 12:14 PM
    Pooner
    Pooner New Member
    white 2006 prerunner
    still selling 5100's?
  16. Jan 22, 2018 at 12:19 PM
    dziner
    Jonathan
    Nope, they are sold.
  17. Jan 22, 2018 at 12:22 PM
    p_chinnici
    p_chinnici Well-Known Member
    Pete
    South Nj
    2015 Trd Pro Access Cab, 2.5 Kings, Dakars
    2.5 Kings all around, HD Dakars -1 OL, Camburg Moog BJ UCA, Leer 100r topper, Prinsu rack
    I’m selling my pro set up ;)
    dziner likes this.
