billy 5100 and aal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dellingerj1, Feb 10, 2012.
  1. Feb 10, 2012 at 4:08 PM
    Dellingerj1
    Dellingerj1 [OP] Well-Known Member
    Josh
    Derby, CT
    08 tacoma base reg cab 4x4 Black Sand Pearl
    Flyzeye led...led liscence plate lights...thats it so far
    Ok...so ive searched and posted and im listening to fellow tw members....im almost sure about going with the 5100 and aal combo....
    However...still have a few questions...
    1.can i run stock springs?
    will i get 3 in of lift out of this....im not looking to correct the rake..infact i like it...i am looking for the most lift i can get out of this combo.
    2. what is my best option for aal in the back and whats the cheapest place to purchase from.
    Thanks
    Josho
  2. Feb 10, 2012 at 4:09 PM
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
  3. Feb 10, 2012 at 5:22 PM
    Dellingerj1
    Josh
    Derby, CT
    can i get away with billys in the front and just and add a leaf in the back to do i need them all the way around....i will not be doing any wheeling
  4. Feb 10, 2012 at 6:23 PM
    REDTRD
    Anthony
    Western NC
    07 DCSB SR5 4x4
    If it was me I'd go all the way around.
  5. Feb 10, 2012 at 6:27 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    the stock rear shocks are too short, you'll end up maxing them out going over speed bumps
    the 5100's lift function is designed to work with stock coils
    and there's many different kinds of AALs..it's up to you!
    personally I run toytec's AAL. havent had any problems with it.
  6. Feb 10, 2012 at 6:39 PM
    Dellingerj1
    Josh
    Derby, CT
    soo billys all four corners and toytec aal and im all set?
  7. Feb 10, 2012 at 6:44 PM
    Dellingerj1
    Josh
    Derby, CT
    do i need the longer billys in the back if im doing an aal or will the 5100 work fin
  8. Feb 10, 2012 at 6:45 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    The 5100 series will work fine with the AAL's.
  9. Feb 10, 2012 at 7:34 PM
    medic2230
    Murph
    Bama! Roll Tide
    Would you need to run aftermarket UCA's with this setup?
  10. Feb 10, 2012 at 7:36 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    If you get them from DSM, they are sold with the longer rear 5100s
    rule of thumb is anything under 3" keeps you safe in the UCA department, stock coils with 5100s on the top setting gets you 2.5"
  11. Feb 10, 2012 at 7:40 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Need no, but i think its recommended if you trash around your truck alot.
