billy 5100 rear shock length?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slizzy, Sep 12, 2013.
  1. Sep 12, 2013 at 6:15 PM
    Slizzy
    Slizzy [OP] Well-Known Member
    BC Canada
    '09 MGM TRD Offroad
    Bilstein 5100's @ 1.75" front & 5100 rear, Pro Comp 7089 16x8 4.5"BS, 265/75/16 Duratracs, color matched grille, black emblem
    I just bought a set of 5100's... the site I got them from in Canada didn't have any rear size options...
    I have the 4 leaf pack in the back.
    would I have to buy the longer shocks if i plan on installing an 1.5" aal?
    or could I raise the back a lil with a block if needed? Im basically looking to level my truck with the 1.75" setting but hope I didnt shoot myself in the foot if I want/need to throw more in the back cause of bro lean/anti rake...
    pls bare with me im new to this stuff but learning :)
  2. Sep 18, 2013 at 6:04 PM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    Bump...
  3. Sep 18, 2013 at 6:08 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I'd go with a add a leaf, blocks could cause axle wrap/
    For the length, the stock ones will work fine as long as you don't lift over 1.5'', when you go to order new shocks just measure the distance from the shock mount points (with the tires off the ground, truck supported by jackstands under the frame) and that's you're extended length, then just find which shocks that have a slightly longer extended length then the length you measured.
  4. Sep 19, 2013 at 12:05 AM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    I bought the regular 5100 sized rear shocks already without knowing I might need a longer length...
    So if I added a 1.5" aal to a 4 leaf (tsb) rear would the reg length 5100 be too short?
    Would I need the longer 5100's?
    I'm just looking to level with the 1.75" setting on the fronts so hopefully I won't have to touch the back...
    Thx for the help hopefully I get this figured out my appointment with the dealership is next week... Eek
  5. Sep 19, 2013 at 12:47 AM
    95 taco
    95 taco Battle Born
    I believe the stock length will work with 1.5'' lift, as long as you don't flex the rear to the max, but i wouldn't be to worried about it.
  6. Sep 19, 2013 at 8:57 AM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    By stock u mean the reg length 5100's?
    I have seen a few reports of guys blowing the rears but ur right it's usually from full flex... I Offroad but not super hard
  7. Sep 19, 2013 at 9:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    5100's come in 2 lengths, stock length and extended. You have stock length.
    I have the same rear shocks, TSB leaf pack and 2" of lift and it does just fine. I went with the 3-leaf AAL from Icon and left the overload leaf in place for an effective 2" of lift. I can flex the rear out just fine without damaging the shocks but, as mentioned above, if you like to go nuts off road then you should get the proper length shocks. For daily driving and mild off roading, the shocks you have will do just fine.
  8. Sep 19, 2013 at 4:46 PM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    Thx for the help man!
    Sweet, so if I needed to or wanted to put a 1.5" aal in the back I would be fine.... That's good news .
  9. Oct 1, 2013 at 8:07 PM
    TacomaSportLB
    TacomaSportLB Well-Known Member
    Dad
    Chambersburg, PA
    2012 Toyota Tacoma TRD Sport DCLB MGM 4x4
    YWM, Front 5100's @ 2.5", Rear 5100's, 1.25" Spidertrax Wheel Spacers, Safety Rack, Fog Light Anytime, DRL Switch, Differential Breather Mod, UWS TBSD63ALPB ToolBox, AMP Research BedStep, Bedrug Tailgate Mat, aFe Air Filter, Dee Zee Heavyweight Bed Mat, Pop & Lock Power Tailgate Lock, Auto Ventshade In-Channel Ventvisors, Stant Locking Fuel Cap, Plasti Dipped Badges
    I set my fronts too 2.5" in feb. and left the rear alone, so I was about an inch high in the nose. I just switched to 5100's in the rear yesterday and for some reason its level now. So it seems you gain an inch of lift in the rear just by adding 5100's. Not sure why but the tape measure don't lie.
  10. Oct 1, 2013 at 8:11 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Did u let the suspension settle or measure it right after u got it off the jack stands?
  11. Oct 1, 2013 at 8:23 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Op.....
    The reg length 5100s are short enough to top out with 1.5" if u wheel.
    The stock sshocks arent long enough (ideally) for the 4 leaf stock setup.... They limit droop substantially and can be easily topped out, but if ur not pushing the truck, u won't notice it. The biggest issue with the longer 5100s is u will lose up travel and have to lower the bumpstops or u will bottom out the shock about 2" before making contact with the bumps.
  12. Oct 1, 2013 at 8:30 PM
    TacomaSportLB
    Dad
    Chambersburg, PA
    I measured after I took it off stands after I noticed it was higher in the rear, remeasured the next day, same deal, I'll remeasure in a couple weeks again.
  13. Oct 3, 2013 at 12:14 AM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    I off road a bit but no rock climbing or hard core stuff...
    I would be stepping up the fronts with longer springs in the future so I wanna take my time and do it right... Thanks...
    So maybe the 5100 would be fine if I didn't rip the truck?
  14. Oct 3, 2013 at 12:41 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I'd imagine so... Based on ur uses it can be fine. If u have a cap or carry a certain amount of weight regularly it may help avoid the topping out too... That's a total guess plz feel free to correct me in my mistake.
    I do run the standard 5100s now and very rarely top them out. They have fallen apart before on other rigs, but its not common, and who knows how hard they were pushed.
    I've ran them for a few years now and being a prerunner I don't exactly abuse them.
    It seemed safer to me to run standards and have enough down travel.... Compared to AWESOME droop and a better ride due to the longer shocks being in a sweet spot at rest and having more travel, but sacrificing my uptravel and bottoming the shocks out well before initial bumpstop contact.
    Hope that made sense.... Haven't bee awake too long, and I'm a Lil groggy in and out of bed.... Took a muscle relaxer for back pain too.
  15. Oct 3, 2013 at 12:42 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I'd also suggest checking out the superbumps from wheelers off road.
    I love em!
  16. Oct 4, 2013 at 1:05 AM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    Man this is confusing ...
    Thx for all the replies ,
    so a 4 leaf pack with a 1.5 aal + reg length 5100 should be ok if I'm not planning on flexing the crap outta it?
  17. Oct 4, 2013 at 2:27 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    measure your height when you get them on to be safe. but at 1.5" you should be fine.
    youre a 2nd gen, and I'm a 1st
    but this was me on a 2" AAL, when I was running 5100's before they offered the extended models...
  18. Oct 4, 2013 at 12:29 PM
    Slizzy
    BC Canada
    '09 MGM TRD Offroad
    I have the 4 leaf and 5100's all around right now... What would I measure, before or after the 1.5 goes on ?
  19. Oct 4, 2013 at 12:31 PM
    Pugga
    Massachusetts
    That's what I have and it's help up well. I don't do anything crazy with my truck but I have gotten it in the woods to flex it out a bit and it seemed to be a good match.
