Billy 5100 setting question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alx_alx_69, Jan 19, 2010.
  1. Jan 19, 2010 at 6:19 PM
    alx_alx_69
    alx_alx_69 [OP] Well-Known Member
    Alex
    Hope Mills, North Carolina
    I am getting my rear spring TSB done tomorrow, which will put 7 inches in between the tire and the frame on the rear, and right now there is 4 and a half inches in the front between the tire and frame.
    If I install bilies in the front and set them at 2.5 will that pretty much make it level, and does setting billies at 2.5 max them out to where they dont perform well?????
  2. Jan 19, 2010 at 6:22 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    From my knowledge...2.5" will not make it level out. Your front will sit higher then the rear. I know most of the people set it at 1.75".
  3. Jan 19, 2010 at 6:27 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    yeah they set it at 1.75 with the TSB, but the front is still lower. If you set the front at 2.5 and get the TSB it should be close to dead nuts level.
  4. Jan 19, 2010 at 6:28 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    This is my truck with the TSB and the billy 5100 set at .85.
    I selected .85 because the TSB settled to only raising the rear 1 inch after about a week. So hense, the rear was raised 1 inch, i set the front at .85.
    You could probably go 1.75 and be good also since our trucks have that factory rake. But everyone who has done the 2.5 seem to be front high to me. Plus going 2.5 really doesnt allow the spring full range of motion.
  5. Jan 19, 2010 at 10:37 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    This has also been a problem with front end alignment issues without changing UCA's? I also set mine at .85" and after a year or so of settling the look is what I wanted being slightly tail high running light and level with a load.
  6. Jan 19, 2010 at 11:02 PM
    sincitytaco
    Las Vegas
    In that pic it looks like the front is about 2 inches lower than the rear. So if you lifted the front to the 2.5 level it may still be lower than the rear. Level to me it level. In other word the wheel well is the same distance from the ground at all 4 corners. If the front sits 1 inch lower, it is not level. It may be close, but it is NOT.
  7. Jan 20, 2010 at 8:43 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    He didn't say it was level, just that the rear was raised about an inch due to the TSB, so he set the Billys to .85. I would assume to match the factory rake. I plan to do the same on mine. I assume, again, that his purpose in posting was to just show what 1" up front and back looks like, as opposed to trying to level it.
  8. Jan 20, 2010 at 8:54 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    To avoid this problem and the lean I opted for coilovers.
  9. Jan 20, 2010 at 8:56 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Look in my gallery, I am set at 1.75 with the tsb, it does settle quickly in the rear...as someone stated above going to 2.5 is going to be a little harsh, and you run the risk of vibrations. Not everyone has them, but it does occur. I think 1.75 is real safe for close to level, and a good ride. No alignment issues as well...
  10. Jan 20, 2010 at 8:59 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    When set to 2.5 my taco looks leveled to the eye.
  11. Jan 20, 2010 at 9:05 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    yeah go with 1.75" setting...you don't want it perfectly level...if you do that at 2.5 the ride will be harsh and when you are hauling something the rear end will be alot lower than the front...to me it looks good at about 3/4" higher in the rear than the front
  12. Jan 20, 2010 at 9:19 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    5100s @ 2.5 with 1.5 AAL with 3 leaf non-TSB pack...1/2 inch higher in back, handled 1500lbs without issue & not on bumpstops, no harsh nothin on pavement, offroad might be a little less than plush like a long travel but nothing crazy bad. The worst thing about going 2.5 up front is that you will need UCAs to get caster adjustment correct for front end alignment. It will not wear tires but will feel twitchy & follow grooves in the road a bit.
  13. Jan 20, 2010 at 9:42 AM
    sincitytaco
    Las Vegas
    I believe he did say 2.5 would be too high.
  14. Jan 20, 2010 at 12:09 PM
    DIRTRIDER
    DIRTRIDER Active Member
    EAST AURORA,NY
    07 WHITE SR5 4X4 V6
    BULL BAR,DRIVING LIGHTS W/ OEM SWITCH,BLACK STOCK WHEELS,265/75/16 TIRES,XM RADIO,EXTRA BED D-RINGS,SPRING TSB,5100'S @ 1.75",FOG LITE MOD, A/C COMP.MOD
    Set my 5100's at 1.75 with the TSB springs and have a 1" difference front to back. The 2.5 setting would have made my front end sit too high. Go 1.75, also, my alignment is in spec and truck rides good.
  15. Jan 20, 2010 at 12:13 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Mine 1.75 billies and the TSB AAL. Front is just lower than the front.
  16. Jan 20, 2010 at 1:13 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    15 Lariat Sport 5.0L
    3rd gen forum caused me to get a Ford
    front is lower than the front.....hmmmm......something to ponder :D
  17. Jan 20, 2010 at 1:34 PM
    skistoy
    Western New York
    Correct, I was trying to stay close to factory. Was originally going to set billys at 1.75, but when i re-checked the rear end it went from 1.5 inches of lift to 1 inch of lift. so that why i decide to go with .85. have been very happy with this set up, plenty of spring rate left. did the alignment after intalling billys, no vibrations, no rubbing, even doing 75/80 on highway.
  18. Jan 20, 2010 at 1:40 PM
    skistoy
    Western New York
    I believe you dont measure level from the wheel wells. The wheel wells are cut at different heights, the rear has a bigger opening. If you have all four wheel well at the same height, you will be front high
  19. Jan 20, 2010 at 3:51 PM
    Hoyal
    Devin
    2013 Tundra
    Hahah yes the front lower than the front. Sorry I ment that the front is lower than the rear at 1.75. I have a lack of sleep and usin my phone to post.
  20. Jan 20, 2010 at 4:30 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    I have mine set at 1.75 and it's even with the tsb rear. I guess it all depends on how the TSB springs settles afterwards.
