Billy 5100 w/o aal
Discussion in 'Suspension' started by dysfunctnlretard, Jun 29, 2009.
  1. Jun 29, 2009 at 12:41 PM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    I just ordered some Billy5100's for all four corners of my '09 taco. The front will be set at 2.5". Given that I don't aal, how much higher will my front sit than my rear? Will there be any performance issues without the aal?
  2. Jun 29, 2009 at 12:45 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I ran 5100's all around no prob front set @ 2.5" no aal i had no issues. The shocks actually leveled my truck out i didnt have the nose in the air but its different for most trucks. But there will be no performance issues.
  3. Jun 29, 2009 at 12:59 PM
    dysfunctnlretard
    Manny
    CA
    2010 FJC
    Ok. Sounds good. Thanx.
    All 5100's are the same right? I adjust the height when I get them right? I don't have to order A preset height right?
  4. Jun 29, 2009 at 1:00 PM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    When you get the you set them up to the 2.5" height and your good to go.
  5. Nov 22, 2009 at 11:55 PM
    671taco
    671taco thekeithchronicles
    Guam
    twenty-ten rc
    i wanna run mine at 2.5 along with a 1.5 wheelers aal.
    but for now i just wanna level it, if i set it to 1.75 will i be level? no tsb and aal just stock springs.
  6. Nov 23, 2009 at 12:27 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I dont see how it would be level with the fronts set at 2.5 and no AAL Im at 1.75 in the front with an AAL and Im just about level.
  7. Nov 23, 2009 at 1:11 AM
    671taco
    Guam
    twenty-ten rc
    are you referring to me?
    im honestly confused now. some say they have 2.5 and 2" aal and they are about level, some say 2.5 and a 1.5" aal and they sit about level, and you say your level at 1.75.:confused:
    i guess it all depends on the truck?
    but if i were to just run 5100 up front for now what should i set them to to be some what level?
  8. Nov 23, 2009 at 1:23 AM
    Hoyal
    Devin
    2013 Tundra
    Im just about level with 1.75 and the TSB AAL. I still have some rake. I just dont see how it could be level with no AAL and the 2.5 setting.
  9. Nov 23, 2009 at 1:33 AM
    671taco
    Guam
    twenty-ten rc
    well if i was going to run it at 2.5 i was going to throw an aal on.
    BUT for now since funds are short i just want to at least run the 5100 only, what setting will be level.
  10. Nov 23, 2009 at 1:35 AM
    Hoyal
    Devin
    2013 Tundra
    I couldent tell you maybe the .85 would look good. Im just going off of what mine looks like with 1.75 and the TSB AAL. I just wouldn't want you to set them at 2.5 and have your front higher than the rear and have to do the process again to get the look you want.
  11. Nov 23, 2009 at 1:47 AM
    671taco
    Guam
    twenty-ten rc
    alright man thanks. i think ill go measure my wheel wells front and back and see what the odds are
