billy 5100's and taco lean
Discussion in 'Suspension' started by 2006KJ, May 13, 2013.
  1. May 13, 2013 at 9:06 PM
    2006KJ
    2006KJ [OP] Well-Known Member
    i have a 2012 DCSB TRD sport... just ordered some 5100's front/rear from downsouth. will i have taco lean? im keeping my factory trd sport springs. If i will have taco lean where do i get the spacer to level it out left to right?
    thanks in advance.. also i've searched for the past 4 hours for the answer to this and havent found it. too many combinations with the 5100's to find my answer.
    I have rear TSB and will be setting the 5100s at 1.75
  2. May 14, 2013 at 8:28 AM
    Geosh
    Geosh Why yes, I AM a rocket scientist.
    Chandler, AZ
    '03 PreRunner DC, 3.4L
    I thought the Taco Lean only had to be dealt with if you swapped out the springs to aftermarket ones. I think the OEM ones are already compensated.
  3. May 14, 2013 at 8:31 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    if you do need the 1/4" spacer plate, just cruise to Ebay...
    also, find level spot, walk around truck measure distance from ground to highest part of flare/fenders, compare, it will tell you whether you need it, or not....
  4. May 14, 2013 at 8:36 AM
    JayC06
    JayC06 Well-Known Member
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    5100's front at 1.75, procomp light bar, kc lights, dynomax muffler
    You shouldn't have any lean with that combo. That's the set up I have. It's level all around.
  5. May 14, 2013 at 8:38 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
  6. May 14, 2013 at 1:40 PM
    2006KJ
    thanks! just the info i was looking for. so the stock suspension makes up the 1/4 inch with the factory strut? so the springs left to right are the same?
    i just want to avoid putting on the 5100's then have to take the drives side all apart again to add the 1/4 spacer. i'd rather just do it the first time.
    anyone with this set up have taco lean? seems like half do and half dont. 5100's set at 1.75 and stock trd sport coils.
  7. May 14, 2013 at 1:52 PM
    2006KJ
    this is what i was hoping... but some say you still get the taco lean with 5100's set at 1.75 and stock trd sport coils.. just trying to figure this confusing taco lean out! :mad:
  8. May 14, 2013 at 1:58 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    again, find level spot, measure to all fenders/flare high spots, you do this before you put in the 5100's, compare, that way you will know BEFORE you do the swap...
    Kapeeeeeeeeesh?
  9. May 14, 2013 at 2:05 PM
    2006KJ
    ive done this.. stock i have no taco lean. i dont want to install the 5100's then check it again incase it does or does not have taco lean after changing to the 5100's. Trying to avoid a second take apart.. put in spacer.. and reassemble.
  10. May 14, 2013 at 4:24 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    If you are using the SAME SPRINGS on the same side (your TRD stock springs), then putting in the 5100's is not going to change anything except the height you pick...the springs make for the height, the shock just dampens the action....
    I apologize for the measurement thing, I went back and reread but didn't see any reference to measuring...
    also, that 1/4" spacer is EZ to install, yes, you have to lower the strut far enough to put the spacer over the three studs that slide through the mounting holes...but you don't have to take the strut apart again, just uninstall/reinstall...
    go for it....
  11. May 14, 2013 at 4:41 PM
    2006KJ
    Thanks for the explanation. When my 5100s arrive I'll just throw them in without the spacer and go from there. Really appreciate the help!
  12. May 16, 2013 at 4:22 PM
    rfsdave
    rfsdave Member
    Dave
    Mass
    '13 TRD Off Road
    5100's all around, fronts @.85, Wheelers 3 leaf progressive AAL with the shortest leaf removed & no overload. (1.0" lift)
    My '13 access cab V-6 auto, with stone stock suspension, had a 1/2" lean at the left front and 3/4" lean left rear. This is with less than 4000 street miles. I put a 1/4 " shim (lean spacer) on top of the strut. This brought the front very close to level. It also helped the rear a little. The rear still leaned 1/2" so I installed a 1/2 " shim plate to even out the rear. I got this plate from streetacos.com. It bolts to the bottom of the leaf pac and comes with a new spring center bolt. They sell 1/4, 1/2 and 3/4" plates. The stock U bolts are just long enough for the 1/2"plate to fit.
    I wouldn't call what I did a lift, but the truck sits a touch taller and looks much better.:D What I am saying is the stock springs DO lean in most cases, most often just the front, sometimes the front and rear, and almost always to the left side.:eek:
    I have heard that Toyota corrected the lean using a different left and right spring, but you couldn't prove it by me. I've checked many 2nd gen tacomas, mine is not the only one......
  13. May 16, 2013 at 5:04 PM
    2006KJ
    thanks for the heads up...ill double check mine!
  14. May 16, 2013 at 5:26 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    simply put, the oem coils are in fact side specific and are COLOR CODED. 1 coil will have a half dollar size dot 1 color, and the other coil will have a different color dot.
    Mine were red/green.
    Keep track of what color came off of what side.....replace them in the same order.
    No need for any lean spacer UNLESS ur truck is already suffering a lean.
    Also, pls make sure u have the spring perch set correctly.... the convex part faces UP. When its set onto the circlip/snapring u should NOT see it (the clip)from the bottom, it should be overlapped by the spring perch
  15. Sep 1, 2013 at 10:32 AM
    Jefferson10
    Jefferson10 Well-Known Member
    San Luis Obispo
    11' TRD Off Road 4x4
    AFE ProDry Drop in Filter, Wet Okole Seat Covers (front and Back),Truck Champ side steps (Black), Debadged, BFG KO2 265/75/16, OME 90021 w/ 885 in front, OME 60091 with Wheelers Progressive AAL pack (1.5") in rear
    I'm planning on doing this same setup. Any luck with the install an no lean?
  16. Sep 1, 2013 at 11:50 AM
    D.Robb
    D.Robb Well-Known Member
    D-Robb
    San Diego
    PreRunner
    5100s all around....front set at 1.75. Rear leaf TSB.
    5100s at 1.75....rear leaf tsb.......no lean
  17. Sep 1, 2013 at 12:09 PM
    jermoids
    jermoids Well-Known Member
    jeremy
    Moose Jaw Saskatchewan
    2016 TRD Sport
    nothing yet
    i don't seem to have any lean either, not that i can see anyway, i couldn't be bothered to measure.
  18. Sep 1, 2013 at 12:46 PM
    Jefferson10
    San Luis Obispo
    I think you may be right with that one. There's so many different options and opinions, for someone who's relatively new to the whole "mod" thing, you can get lost really quick. As for the TSB, that's the rear spring harsh ride yeah?
  19. Sep 1, 2013 at 12:47 PM
    Jefferson10
    San Luis Obispo
    P.S. Both trucks look good.
  20. Sep 1, 2013 at 12:51 PM
    jermoids
    jeremy
    2016 TRD Sport
    nothing yet
    thanks. i do think that happens on here but i removed that part of my post becaue there is also a ton of useful info/help on here. i definately have found myself worrying about things that i never would have ever known about if i wasn't on tw, but probably have found more positive info.
    i don't actually have the tsb, my truck came stock with the 4 leafs, i do have 1" blocks in the back that i can't even tell are there, ride is perfect.
