Billy 5100's came today......
Discussion in 'Suspension' started by roggs01, May 6, 2009.
  1. May 6, 2009 at 7:45 PM
    roggs01
    roggs01 [OP] Roggs01
    Surprise, AZ
    16 TRD Sport
    Predator steps,Method NVs, 285-70-17 KO2s
    Hey, I've read all the posts regarding the 5100's and am still in the air in terms of which setting for the fronts. I have the rear TSB done already and am unsure if I should roll with the 1.75" or the 2.50" setting. Seems like the 2.50" settings are a little nose high, correct me if I wrong folks. Not sure if the 1.75" will be enough. Going for a level ride now and will upgrade my coils/UCAs later. If it weren't for this economy, I'd do it all at once. Any pics provided whould surely help. Thanks! :confused:
    Chris4X4 - hope you can provide me your 2 cents...
  2. May 6, 2009 at 7:46 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    1.75" should level it out nicely
  3. May 6, 2009 at 7:47 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    Is that what you have
  4. May 6, 2009 at 7:48 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go with 1.75..........ass end will settle a bit, and it'll be perfect. at 2.5, after it settles, you may be a tad higher in the front.
  5. May 6, 2009 at 7:49 PM
    TacoNut
    Adam
    Denver, Co
    I have it set at 1.75 W/ no TSB
    and thx for reminding me I have to get around to that haha
  6. May 6, 2009 at 7:52 PM
    TSubatis
    TSubatis Well-Known Member
    Boston, MA
    2007 DC 4x4
    Billstein 5100s + Toytec TSB AAL, 17" Moto Metal Blacks, 275/85 Toyo Open Country A/T's, BHLM, Satoshi Grill, Sport Hood, Kenwood DNX5120, Kicker Speakers
    What about setting it to 2.5" and then getting the Toytec AAL for TSB? will that sit level? (interested in mounting larger wheels/tires)
  7. May 6, 2009 at 7:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that should work just fine. should be pretty damn level with the aal for the tsb springs.
  8. May 6, 2009 at 8:01 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    TSB was done over 6-months ago and the rear never settled and is still raised a bit. Debating doing the Toytec AAL but that is a 1.5" leaf.
  9. May 6, 2009 at 8:04 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    This is how she looks now... Notice the severe front rake....
  10. May 6, 2009 at 8:06 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    Driveway is uphill.....look at wheels and gap w/fender
  11. May 6, 2009 at 8:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think you'd be happy with 1.75................you can always take them back off and set them to 25 if you dont like it the other way.
  12. May 6, 2009 at 8:09 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    1.75 for sure with tsb will level right out...doesn't 2.5 cause some vibrations or drifting
  13. May 6, 2009 at 8:11 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    Will any other parts be needed for these shocks? or is everything included. Purchased from Down South Motor Sports.... Sonny has awesome customer service.
  14. May 6, 2009 at 8:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    as far as i know.....everything you need should be included.
  15. May 6, 2009 at 8:17 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    Thanks Tacomaman06.... Alway appreciate hearing what you and Chris have to say. Keep up all the good work. Still waiting for Chris to chime in.
  16. May 6, 2009 at 8:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no problem buddy.....thats what we are here for.:)
  17. May 6, 2009 at 8:31 PM
    TacoNut
    Adam
    Denver, Co
    Sonny is an awesome guy, Great service.
    Everything you need is included. IIRC you'll get the washer the dirt gaurd sits on and the bushing for the top. I may be wrong but you'll have everything you need. are you planning to install yourself???
  18. May 6, 2009 at 8:34 PM
    roggs01
    Surprise, AZ
    16 TRD Sport
    As of now, a buddy at work is going to do it. I was kinda wondering if I need that 1/4" spacer for the drivers side.... Or is that only needed when I change the OEM springs?
  19. May 6, 2009 at 8:46 PM
    TacoNut
    Adam
    Denver, Co
    you're fine w/o it. The most popular spacer i've heard of people adding is to compensate for any sagging from OME springs. Keeping the stock springs you'll be fine. There is a trim packer you can put on one side to compensate for the "taco lean"
  20. May 6, 2009 at 8:54 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    The drivers side is usually a 1/4 to 1 inch lower, so if that bothers you, you will need the spacer.
