Billy 5100's or 3" ToyTec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Incognito, Jun 8, 2009.
  1. Jun 8, 2009 at 3:13 PM
    Incognito
    Incognito [OP] No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Hey guys, I've seen tons of trucks here and to be honest, I've loved them all. I was wondering wether to get Billy 5100's or a 3 inch ToyTec lift, but I need some suggestions. I would like to get my truck as high as possible between the 3 inch lift kit and the Billy's, but I also want something that isn't expensive to buy or to install. So here's my goal: Something cost effective to buy and install but looks awesome at the same time. :D
  2. Jun 8, 2009 at 3:31 PM
    BP09
    BP09 Active Member
    Socal (SanDiego)
    2009 dbl cab sb
    good question and I am also curious for a response since I just bought my brand new 09 dblcab and want to lift it up a little to fit 33s. dont mean to intrude on your thread either but just don't want to start one of my own.
  3. Jun 8, 2009 at 3:42 PM
    Faskev
    Faskev Well-Known Member
    If you want something cost effective then go with the Bilstein 5100's. If you absolutely want 3" of lift then don't settle for anything less than the Toytec Ultimate Lift Kit (coilovers with aal). There are cheaper ways to go 3" but I won't list them as you both have 2009's and there's no point in putting a cheap solution on your brand new truck. Sounds harsh but I highly recommend saving up and putting a good lift on and being happy with the ride etc.. than putting in a low budget lift and having your new truck ride like a shopping cart. The 5100's give a nice lifted look and don't sacrifice ride quality as well as being fairly inexpensive. That extra half inch won't make a huge difference so if you need 3" then save up and shy away from spacers. If you are mostly rolling on the streets then a spacer lift might suffice.
  4. Jun 8, 2009 at 4:14 PM
    Incognito
    VA
    Nice! Thanks for the responses guys! :)
    SecretSquirrel: Could you post a link to the correct top plate from ToyTec? I already know about the Billy's but not too sure which top plate you're talking about. Sorry! :eek:
  5. Jun 8, 2009 at 4:23 PM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    I was going to respond but this answer is an excellent response. This is the same mindset that should be used on most all purchases and upgrades. Do the homework and make your dollar stretch farther.
    Rob
  6. Jun 8, 2009 at 5:00 PM
    Incognito
    VA
    SecretSquirrel: So I would need 4 of those, right? Just making sure I have everything set before I make the final purchase.
    Thank you Faskev and zero niner for the feedback! I really appreciate it! :)
  7. Jun 8, 2009 at 5:26 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Squirrel is correct. You need (2) plates, one for each FRONT coil, and the rear will be an AAL or leaf pack spacer. The AAL is the better option.
  8. Jun 8, 2009 at 5:27 PM
    Incognito
    VA
    No AAL just TSB. :confused: So just 2? Wow, I'm really :der: when it comes to the suspension. :p
  9. Jun 8, 2009 at 5:40 PM
    ffblaze911
    ffblaze911 Well-Known Member
    Frederick, Colorado
    TRD OFF ROAD
    Supercharger
    hey i was in the same situation and i went with the toytec much happier and you will be to.. i also have a 2009 and i figured that i want to do it right the first time and not worry about it.. also with the toytec you have the warranty.
  10. Jun 8, 2009 at 5:54 PM
    Incognito
    VA
    Ok, so I would need these: http://www.toyteclifts.com/index.ph...ategory_id=64&option=com_virtuemart&Itemid=72
    And these: http://downsouthmotorsports.com/i-1...acoma-pre-runner-4wd-pre-load-adjustable.html
    Am I right?
    Also, I found a ReadyLift kit for about the same price as the Billys. :http://www.readylift.com/c-104-tacoma-prerunner-sst-lift-kit-2005-2009-2wd-4wd-275-30f10r.aspx
    I'm lost as to which one... :rolleyes:
  11. Jun 8, 2009 at 6:22 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Colton,
    Also keep in mind that at 3" you'll need to consider the UCA's because at this height, there may be issues... Also if you don't have the TSB (search more) and will be considering this, make that your first move as there will be a height increase.
    Well let me save you some time if you want to know if you need the TSB, how many leaf springs do you have in the rear? Just 3? OK, now you have another project.
    Best of luck with your lift, I just did the 5100's in front with 1.75" and the TSB with a 1" block in the rear. It's forward canted but I dont' mind. It also looks much tougher with this lift. I'm just a prerunner so I went with a mild lift.
    Welcome aboard!!!
    Rob
  12. Jun 8, 2009 at 6:48 PM
    Incognito
    VA
    Thank you so much for your contribution, SecretSquirrel. :)
    Rob, Thank you! I really appreciate it. :) EDIT: Do you have any pics of your truck?
  13. Jun 8, 2009 at 6:56 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Sure do, just click on the camera to under my screen name, the photos are labled appropriately so you can see the differences.
    Best of luck with your search, let me know if you have any questions. I will say this. I had not thought I'd do the TSB so I only went 1.75" up front, in hindsight, I would have done the 2.5" and called it good without having to do the UCA's...
    Rob
  14. Jun 8, 2009 at 6:57 PM
    BBQ BOY
    BBQ BOY Well-Known Member
    What is TSB?
  15. Jun 8, 2009 at 7:05 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Search TSB there is plenty about it... It specifically means Toyota Service Bulletin but I was referring to the rear leaf spring TSB for this thread.
    Rob
  16. Jun 8, 2009 at 8:12 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
