Billy 5100's with 885 OME lift coils?
Discussion in 'Suspension' started by Redfox1, Jan 20, 2010.
  1. Jan 20, 2010 at 2:26 PM
    Redfox1
    Redfox1 [OP] 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
    Hey everyone. About 2 weeks ago i put 275/70/17 BFG A/T T/As on my 09 DC LB, and they rub when braking on turns. I was thinking about putting Bilstein 5100s all the way around and the OME 885 Lift coils in front from Toytec. So with this setup i could get 2in lift in the front with the Billys at 0? Would i run the chance of sporting the infamous taco lean? I would also try to weasel the add-a-leaf tsb from toyota. If i did get the tsb could i set the Billys higher to get a little more lift in the front? Any Advice?
    OME Lift Coils from Toytec
  2. Jan 20, 2010 at 3:29 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Negative on using the 5100's above the stock setting with the 885 coils. That means you are preloading an extended spring-and can make for a less than ideal ride and is not the way the 5100s are designed to be used.
    As far as using the OME coils- Why not get the OME trim packer and the OME shocks- They are valved/designed to be used with the OME coils.
    Should have to "weasel" anything- 09s are included and if you have the complaint/problem then have them address it. It's not REALLY an AAL either- It's a complete replacement leaf pack.
  3. Jan 20, 2010 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What He said ^^^^^^^^^^^^^^
  4. Jan 20, 2010 at 4:57 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    and what he said too... :)
  5. Jan 20, 2010 at 5:19 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Try closer to 3" with the 885's. As member here is selling a set of new Eibach springs. They will provide 1.6" of lift and stock shocks can be used. If not, you could add the 5100's up front. Go with the 0 setting as the Eibach is a 620# spring and if you set the 5100's higher, well just keep a few walnuts to crack inside the truck.
    Or, go with the OME 884's/5100. About 2" of lift and a smoother ride as the OME 884's are a 590# spring.
  6. Jan 21, 2010 at 10:33 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    read sincitytacos post on what happened to him when he added the eibach to the stock bilstein
  7. Jan 21, 2010 at 10:39 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    If you go with ome coils get the ome shocks not the 5100's. If you go any other route other than the ome then go with the 5100. The ome coils do lift 3" and to get around the taco lean you get a 1/4" top plate spacer ant intall that on the driver side.
    Pretty much ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^what they all said before me :)
  8. Jan 21, 2010 at 11:16 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    toytec recommends the ome shocks with the 885 and 886 coils...but what is the difference with the 884 or 883 coils with 5100s or the ome shocks?
  9. Jan 21, 2010 at 1:44 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Mo money for the OME shocks...I have the 886 with 5100 and there's no problem with the shocks. Just be prepared to get new UCA's.
  10. Jan 21, 2010 at 3:47 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The OME shocks are more expensive but they are designed with the OME spring rates in mind when the valving is set up.
    You can use them with the 5100s....but I'd rather have the equipment built to go together.
  11. Jan 21, 2010 at 5:20 PM
    Redfox1
    Conner
    Thanks for the input everybody. When most people install the 5100's, what coils do they use? If i purchased the Bilsteins what else would i need to get to avoid any problems. I will also look into using OME Shocks and coils but, am still kind of leaning toward Bilsteins.
  12. Jan 21, 2010 at 6:40 PM
    Masada
    Taylor
    Laveen, AZ
    I think most people go with Eibach for the coils, at least that's what I have seen.
  13. Jan 21, 2010 at 7:03 PM
    SwampThing07
    SwampThing07 Well-Known Member
    Orlando, Fl
    07 prerunner/ Toytec lift/ 285 nittos/ MM 951
    885/ w 5100's, Grillcraft, HIDs, 285 nittos, MM 951B, Flowmaster duals, blackout tailights, tint, Sirius.
    I have 5100's with 885's. I love the setup. I also used to have ome shocks paired with the 885's. For me they rode a little too soft. The 5100's make it feel more like a truck.
  14. Jan 21, 2010 at 10:15 PM
    spiceman
    spiceman Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    I have the Eibachs with 5100s set @ .85 and the ride is fine. I only got about 1" of lift set at 0 and got about 1.75" at .85.
  15. Jan 21, 2010 at 10:30 PM
    Redfox1
    Conner
    Your setup sounds pretty appealing spice man. I think i might go that route.
  16. Jan 21, 2010 at 11:01 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    this is what i have and as long as the billies at at 0 ur fine
  17. Jan 22, 2010 at 1:20 AM
    kilgoja
    Alabama
    :mudding:
    well i have a reg cab so the 885 and 886 coils are too heavy of springs for me...they recommend using the ome shocks for those heavy springs....instead to level my truck out they have suggested i use the 883 ome springs (500lbs) and get the 5100 shocks and set at 0"...will get about 1 1/2" of lift on the front....they say they have used the 883 springs with the stock shocks and it was ok but of course the billy's would be better....this will be a much better ride than using the stock springs on the billy's and setting it at 1.75".....since with the stock springs you would be compressing the springs and with the ome springs they won't be compressed to get about the same amount of lift
  18. Feb 5, 2010 at 2:46 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Has anybody tried 884's plus 5100's set at 0? How much lift would a dbl cab, prerunner get up front?
    I'll be measuring the heights this afternoon but for now i'm leaving the back as it is with the TSB and just want to get the front to get level with the rear. I'm thinking somewhere around 2" should be close to level? Like i said, i'll be measuring the difference tonight but I'd like to get someone's input.
  19. Feb 5, 2010 at 2:49 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Well they always recommend 885's with a double cab since the extra weight. 884' are mostly made for the access cab Tacoma's.:cool: I have 885's on my 5100's set at 0" and I got a full 3" lift out of it with the top plate spacer.;)
  20. Feb 5, 2010 at 3:07 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    ^me too ome 885 w/ spacer on bilsteins set at 0
