Billy 5100's with 885 OME lift coils?
Discussion in 'Suspension' started by Redfox1, Jan 20, 2010.
  1. Feb 5, 2010 at 6:38 PM
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    Well my understanding is that the 884 & 885's are both a 590lb spring rate, same coil diameter but just shorter. Doesn't that mean that the weight wouldn't matter? It might not have as much "travel" as a longer shock obviously because it's shorter but there won't be as much space between the wheel and wheel well anyway. Is my thinking correct?
    The only reason i'm considering the 884's rather than the 885's is because I don't want a full 3" lift. I'm aiming for 2-2.5" max of lift. I won't be putting in UCA's, so close to 2" of lift would be ideal to keep alignment specs reasonable while trying to avoid issues down the road.
  2. Feb 5, 2010 at 6:41 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Just get the 885's and dont put in the top plate spacer.;)
  3. Feb 5, 2010 at 6:43 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    I just put some Nitto TG 265/70/17 on the stock sport wheel so i don't want it to look funky being at 3" with that size tire and I also want to avoid alignment/vibration/wear issues.
  4. Feb 5, 2010 at 6:44 PM
    619Tacoma
    Call me Rocco
    San Diego, CA
    how much more lift does the top plate spacer give?
    Is the top plate spacer the one people use to correct the taco lean?
  5. Feb 5, 2010 at 6:50 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    The top late spacer gives it about another 1/2" of lift. And no, its not for the infamous taco lean.:cool:
  6. Feb 6, 2010 at 6:19 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    mine gave about an entire 1" the spacer itself is 1/2"
  7. Feb 22, 2010 at 12:25 PM
    Hunter'06FLKY
    Hunter'06FLKY Well-Known Member
    Central Florida
    08 Access Cab SR5 4x4
    Bilstein 5100's on all 4 corners, OME 884's, Toyotec AAL, Differential Breather, PIAA Fog's, K & N Air Filter, Definity Dakota M/T's, Cherry Bomb Extreme High Clearance
    So with the 884's and the Billstein's you don't need UCA's? That's probably what i want to do but can't afford new uca's
  8. Jun 4, 2013 at 11:49 PM
    emilminasian
    emilminasian Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    How much lift did you get with this set up?
  9. Jun 5, 2013 at 6:52 AM
    thelivestone
    thelivestone Well-Known Member
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
    subbd. same setup I'm putting on.
  10. Jul 26, 2013 at 10:43 AM
    4WDTrout
    4WDTrout Well-Known Member
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    -As another TW Member asked, How much lift did you get up front from this setup?
    - What rear setup did you go with to keep everything level?
    - What did you use to fin the 'Taco Lean"?
    From what I've read, I believe that PreRunners will get more lift than a 4x4 and if you have a Double Cab, you'll get less lift than a Xtra-Cab.
    I have an 08 4WD Double Cab and am looking to have my truck lifted 2.5"(no more) in front, sit level, ride relatively smoothly, have minimal body roll, and have No Taco Lean. I know buying Icon Coilovers will do this(in the front at least) but, I'm wanting to spend less money if possible. Advice is appreciated.
  11. Jul 26, 2013 at 11:00 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    Sacramento
    2008 TRD Off-Road
    Little this. Little that
    ^ Yup, same as mine.
    5100 @ 0", OME 885, Top plate spacer. I got almost 3.25" lift, but it has settled to 3" It is a bit stiff. but I like it. Feels like a truck.
    I plan to go back to stock springs and 5100's @ .85 when I get my Maxtrac spindles.
    Oh and get new UCA's if you're going to lift past 2.5. Generally its recommended for 3"+ but Sitting at 3 I'm already noticing I'm going to have to get new UCA's. I've had the lift for a month.
  12. Jul 26, 2013 at 11:03 AM
    t.hornstra
    Ted
    Sacramento
    2008 TRD Off-Road
    Just run 5100's and OME 885 coils. That'll put you right at 2.5, and it will settle a hair. I ran this with the driver side at .85" it 'fixed' the lean, but sorta shifted it a tad higher than the passenger, which is fine cause when I'm sitting in it, it sits level. After a week I wanted more so I put top plate spacers in too.
  13. Aug 1, 2013 at 11:25 PM
    jsturner44
    jsturner44 New Member
    Jacob
    Alabama
    07 TRD off road Barcelona red
    BHLM, Satoshi grill, dipped lower valence, 2525 aeroturbine muffler, 3" rough country lift, 17" XD spy rims, 33-12.50-17 Dean mud terrain tires.
    Ok first of all this is my first post. I have a 07 dcsb trd offroad with a rough country spacer lift and I'm looking to get rid of it for something better. I already have a 1.5" block in the rear and am running 33"s so I guess I'm looking for 2.5"s of lift in the front. What does it take to acquire this, the 885 with billys set at zero or do I also need the spacers? I have looked high and low on this sight and have found different answers everywhere.
    Any and all replies will be greatly appreciated.
  14. Aug 2, 2013 at 7:49 AM
    Anthonyjames
    Anthonyjames Member
    Corona, Ca
    Black 2013 trd offroad
    Tint, leather
    Im looking to lift my truck as well. And I'm wondering I I need to add a leaf in the back if I lift the front? I have. 2013 crew cab trd offroad. Any input?
  15. Aug 2, 2013 at 7:54 AM
    #35
    motionridr8
    motionridr8 Well-Known Member
    Drew
    WI
    2012 Tacoma 4x4 DCSB
    5100's/886's, ICON AAL, JBA UCAs, US Offroad Bumper, Badlands 9000lb Winch w/ Amstel Blue Synthetic Line, Rigid LEDs, TRD Exhaust
    I run the 5100's set at 0 with 885's on my DCSB. Ride I great. Got about 2.75" of lift. Using a 1/4" spacer on the drivers side to correct the lean. You'll be fine with 5100s/885s as long as they are set at 0.
  16. Aug 2, 2013 at 7:55 AM
    #36
    motionridr8
    Drew
    WI
    you'll need something for the back. I did the ICON Progressive AAL and it leveled me our perfectly. check my signature for build details.
  17. Aug 24, 2013 at 4:20 AM
    #37
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    nice looking truck man :thumbsup: just curious, why did you go with the 5100s instead of the OME shocks when you added the 885s
  18. Mar 14, 2016 at 11:31 AM
    #38
    TacoTRD78
    TacoTRD78 Jello taste like Jello
    Stuart,fl
    15 tacoma trd off road
    All Pro Rack Smitty built RTT KC Cyclone bed light Anti Dark under the hood light 4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod Ditch mount Lights with CBI brackets
    So if i run 5100's set a zero with 885's ill get like 2.5" up front should i do 2" or 1.5 aal in the rear i also have a topper.
