Billy 5100's
Discussion in 'Performance and Tuning' started by Dr_Kevorkian, Dec 24, 2010.
  1. Dec 24, 2010 at 1:11 PM
    Dr_Kevorkian
    Dr_Kevorkian [OP] Well-Known Member
    California
    2nd Gen Pyrite Mica AC
    I want to order bilstien 5100's but have a couple questions before ordering them!
    1-Are the 1st gen ones adjustable in the front so i get the lift?
    2-If they are adjustable in the front, my trucks gonna sit slanted since im guessing the rear ones arnt adjustable so what would you guys recomend in the back to level it out?
    3-I know you can use the stock coilovers the taco comes with but what coilovers would you guys recomend?
    Thanks in advance guys!
  2. Dec 24, 2010 at 1:18 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    1: Yes they are adjustable
    2: An AAL (add-a-leaf) is your best bet for the back
    3: They are designed for use with the stock springs. If you use aftermarket coils, you should set the billy's so that you don't exceed 3" of total lift (coils+billys)
  3. Dec 24, 2010 at 1:29 PM
    Dr_Kevorkian
    California
    What kind of AAL would you recomend? Is there a way you can send me a link?
    So you saying dont exceed 3'' of total lift but arnt they only adjustable t0 2.5''?
  4. Dec 24, 2010 at 1:36 PM
    KPT
    09 Prerunner
    I would recommend a Toytec AAL.
    http://www.toyteclifts.com/index.ph...rt&page=shop.browse&category_id=116&Itemid=72
    The billy's are adjustable to 2.5" of lift with the stock coils. If you use aftermarket coils, which lift the truck by themselves, then setting the billy's higher will give you additional lift.
    Say the aftermarket coils lift the truck 1.5". Setting the billies at the highest setting will give you 4" of lift (2.5" from the preload from the shocks, 1.5" from the springs themselves).
    I would not recommend going any higher than 3" total. In fact anything over 2.5" and you will likely need new UCAs (upper control arms) which are pretty pricey.
  5. Dec 24, 2010 at 1:48 PM
    Dr_Kevorkian
    California
    alright man coool. I appreciate all the help. One more question, if i dont get the AAL and just set the front to 2'', what long term problems will i be facing?
  6. Dec 24, 2010 at 1:49 PM
    KPT
    09 Prerunner
    You'll be fine with that setup.
  7. Dec 24, 2010 at 1:56 PM
    Dr_Kevorkian
    California
    so i just called 4wheelparts and they said for 2004 they dont come adjustable and only adjustable for 05 and up....hmm
  8. Dec 24, 2010 at 2:02 PM
    KPT
    09 Prerunner
  9. Dec 24, 2010 at 3:40 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    Great job on rep'in DSM!!! Even though we didn't win i checked their prices and DAMN! They are responsive and great prices!!
  10. Dec 24, 2010 at 4:54 PM
    Dr_Kevorkian
    California
    alright to finish up this tread, i can get the front to 2'' without aal in the back and i shouldnt have any long term problems. One more question before im done, will installing these 5100's void my warranty?
  11. Dec 24, 2010 at 4:58 PM
    KPT
    09 Prerunner
    It will not. Google the "magnuson-moss act". Your warranty cannot be voided. The dealer only has the right to deny an individual claim if they prove that the aftermarket parts directly led to the failure.
  12. Dec 24, 2010 at 5:01 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You have a warranty?
    You can only set 1st gen 5100's to 0, 1.25 or 2.5 unless you get this kit
    or the entire kit like this
  13. Dec 24, 2010 at 5:20 PM
    Dr_Kevorkian
    California
    ya i have warranty. Can you send me the link to where you found that entire kit at?
  14. Dec 24, 2010 at 5:21 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  15. Dec 26, 2010 at 12:10 PM
    Dr_Kevorkian
    California
    alright bro, a couple more questins, bare with me here
    1- in running stock 265/70/16 bfgs. if i got with the 2.5 setting in the front and the AAl in the back, will the gap be too big and tires look too small?
    2- if i just set the front to 1.25'' and leave the back without the AAL and just the billies, will it sit slanted?
    3- if i want to go 2'' in the front, is there a coil that will give me the remaining .75''
    3-
  16. Dec 26, 2010 at 6:16 PM
    KPT
    09 Prerunner
    I can't answer specifics because I have a 2nd gen, but here's a bump for you.
    You also might want to PM a moderator to get this moved to the suspension forum...you'll get a lot more hits over there.
  17. Feb 4, 2011 at 10:16 AM
    Dr_Kevorkian
    California
  18. Feb 4, 2011 at 10:25 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Their shocks suck. Don't waste your money.
