Billy install question
Discussion in 'Suspension' started by qckslvr2234, Apr 21, 2012.
  1. Apr 21, 2012 at 3:39 AM
    qckslvr2234
    qckslvr2234 [OP] Well-Known Member
    Maryland
    06 Double Cab
    5100's at 2.5, taco lean spacer, Wheelers 3 leaf aal, sway bar relocate, Nitto terra grapplers 285/70/17, spidertrax, custom fishing rod holder, afe drop in filter, 15% tint on front 35% on back, access original roll up cover, BHLM, LED's in cupholder, Plasti-dip badges
    Sorry for a repost if it is but I am installing the lift in two hours. I am putting billy's at 2.5 with stock coils on the front with a spacer for the lean.
    Question is for the spacer do I build the coil assembly, decompress it and then put the spacer on top of coil assembly prior to install back on the truck?
  2. Apr 21, 2012 at 4:15 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Yes.....to my knowledge but haven't done it before. It will go between the coil mount and the shock itself. The alternative would be a spacer inside the coil assembly pre-loading it but that's not the case!
    Good luck man and have fun!
  3. Apr 21, 2012 at 4:22 AM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Correct. Good luck.
  4. Apr 21, 2012 at 6:49 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Pretty sure the spacer goes on top of the assembled strut , over the tower studs & then shove the whole mess up into the shock/strut tower.
    is your spacer the kind that just slips over the existing studs or does it bolt to the strut first & then shove it up the shock tower to put nuts on extended studs or ??? :notsure:
  5. Apr 21, 2012 at 7:27 AM
    qckslvr2234
    Maryland
    06 Double Cab
    Sorry for another question but I put the spacer on top of the assembled strut and shoved it back in. Now when I tightened everything up it looks like the coils is hitting the UCA. Any help please I am litterally doing this right now. Still on jack stands no tires on.
  6. Apr 21, 2012 at 7:44 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    How big is the spacer? 1/4 or 1/2 inch or more?
    It it just barely touches you can try to rotate the coil and find a place it wont touch.
  7. Apr 21, 2012 at 7:49 AM
    qckslvr2234
    Maryland
    06 Double Cab
    The spacer is just for the taco lean. I think once i put it at ride heigth it should be ok. Just barely hitting while the suspension is at full droop on stands.
  8. Apr 21, 2012 at 11:11 AM
    qckslvr2234
    Maryland
    06 Double Cab
    Is there a way to compress the front strut to rotate the coil without taking the whole thing apart again?
  9. Apr 21, 2012 at 11:25 AM
    DDD
    Derek
    Santa Clarita, CA
    I would use this method if it were me. But many think it is dangerous.
  10. Apr 21, 2012 at 11:34 AM
    Large
    Large Red
    This way is a lot safer than the coil compressors they sell.
