Billy suspension setup advice???
Discussion in 'Suspension' started by krisjw101, Jan 3, 2010.
  1. Jan 3, 2010 at 12:01 AM
    krisjw101
    krisjw101 [OP] Well-Known Member
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Autobot in my rear window
    I have been thinking about doing a suspension lift on my rig for a while now. I am a poor college kid and I want to get something pretty good but not really spendy. I was thinking about doing Billies all the way around and set up front at the tallest setting with a new leaf pack in the rear. I don't really offroad a bunch, just when the old man and I go hunting old Wielly White Tail.
    1. Is this a good a pretty good set up?
    2. Should I get a new leaf pack or is an AAL fine?
    3. Would it be a good idea to get lift springs for the front and set the shocks lower rather than doing the stock springs with shocks set all the way up?
    4. Recommended tires and size?
    5. Any other advise or recommendations?
    6. What can I do to avoid geometry issues," the shutter"?
  2. Jan 3, 2010 at 1:30 AM
    mbaltonv
    mbaltonv Active Member
    Moscow, ID
    02 extra cab manual 4x4 TRD
    Front Bilstein 1500's 2.5", 1.24" rear schakel, 2" rear AAL, Swaybar disconnect, 265X75R16 BFG T/A ko
    I just did Billy 5100's on my truck, the ride is improved. I also installed a long AAL from Stanley Springs, and I really like it. I expected a harsher ride, but not really more firm but still retains the flex. I would recommend it if you are on a budget especially if you don't off road a bunch.
  3. Jan 3, 2010 at 1:31 AM
    mbaltonv
    Moscow, ID
    Also, at 2.5" in the front I have no shutter problems. I suppose if you were worried about it you could go with a diff drop.
  4. Jan 3, 2010 at 11:39 AM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    ok thanks for the input
  5. Jan 3, 2010 at 11:44 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Im running Billys at 2.5" in the front with the Icon AAL, the set up is really nice handles great on the dirt and on street, but i also have my sway bar removed.
  6. Jan 3, 2010 at 11:57 AM
    4milestogo
    4milestogo Well-Known Member
    North East, Indiana
    2005 DC SR5
    885's, 5100's, Toytec top plate spacers, LR UCA's & 2"' AAL, black two tone, debaged, BHLM, smoked taillights, smoked lamin-x fogs, Grillcraft upper & lower, afe CAI and Dynomax SS cat-back.
    I have 5100's at 2.5" and 1.5" AAL and it's ok but there are better ways to get the 2.5" - 3' of lift
    You might think of adding 885 springs with your 5100's set set at 0" and some UCA's so you can get your alignment correct, thats my next mod.
    The 5100's are ok for the lift but the 885 springs are better and without adding some UCA's you can't get enough caster so you truck will wonder a bit.
  7. Jan 3, 2010 at 11:58 AM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
  8. Jan 3, 2010 at 12:10 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    ^^^ should I also look into a trim packer to avoid the "lean"? Not sure if that is actually an issue just thought I would ask.
  9. Jan 3, 2010 at 12:29 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    add a 1/4" spacer to the driver side to level out the ta lean
  10. Jan 3, 2010 at 12:44 PM
    4milestogo
    North East, Indiana
    2005 DC SR5
  11. Jan 3, 2010 at 1:01 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    Ok are the ucas something that I need to do right away or can a wait for a bit to save up some more money? How will it affect the ride of the truck, will it just wonder a bit because of the caster/
    By the way 4milestogo I took a look at some of your pics....nice rig. It looks really clean and mean. I like the headlights, looks bitchin!!!
  12. Jan 3, 2010 at 1:12 PM
    krisjw101
    Kris
    Spokane,WA
    09 Tacoma 4x4
    ^^^^Has any body heard of the trim packer splitting or cracking? Just wondering because its only 1/4".
  13. Jan 3, 2010 at 1:15 PM
    4milestogo
    North East, Indiana
    2005 DC SR5
    Thanks, yes you can wait on the uca's you just won't have the correct camber and caster settings.
    Check out some of the alignment threads for more info.
