billy5100 setting
Discussion in 'Suspension' started by bamadawg2009, Jun 28, 2013.
  1. Jun 28, 2013 at 8:20 PM
    bamadawg2009
    bamadawg2009 [OP] Member
    Richard
    Quincy Fl
    04 tacoma sr5
    3" leveling kit in front with add leafs in rear with 3" body lift and 35's on the way
    So after 4 years of my spacer/leveling kit my shocks are shot and Im tired of the spacers so I'm going to replace the 3" spacer with eibach 3" lift springs and 5100 billys. My question is with the lift spring what setting do I ned to set the billys at when I get into the project.
    Im also wondering if I can set the shocks a little higher to get another inch out of the lift or will I screw something up. I want to go back to 35s and clear the frame rail at full lock and I cant do it with a 3" suspension lift and 3" body lift so if I could get another inch in the front end I would be clear of the frame rails at full lock.
    Im finally putting in the differential drop as well while I have the front end tore apart Im tired of blowing cv boots 4 in 4years.
  2. Jun 28, 2013 at 8:35 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    4x4 especially shouldn't go above 3" suspension. If you do, the new cv boots won't last very long. I suggest putting the billies at 1st setting (stock ride height). Allow the coil to provide the 3" of lift. Setting the billies to the 2nd notch will preload the shock and make the ride very stiff. After the research I've done I would advise against putting the billies on 2nd notch with EIBACH coils.
  3. Jun 28, 2013 at 8:54 PM
    bamadawg2009
    Richard
    Quincy Fl
    04 tacoma sr5
    Yeah I kinda figured I was at max lift were I was for my gen 1 taco, and I figured it would be a long shot to add anything by trying to use the shocks for more lift along with the springs. I really am ready to get the diff drop in though cv boots and axles are getting expensive. Thanks for the advise Moe.
  4. Jun 28, 2013 at 8:54 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    eibach coils MUST stay on the stock setting on 1st gens.
