billys 5100's install
Discussion in 'Suspension' started by RDAY, Jun 10, 2009.
  1. Jun 10, 2009 at 4:38 PM
    RDAY
    RDAY [OP] Well-Known Member
    NY
    07 Tacoma SR5 4x4
    I just ordered these plan on setting the fronts at 2.5" and getting a 1/2" top plate spacer. and adding the 1.5" add a leaf for the tsb in the back. and also getting the light racing uca ( no offroading) I have a friend who has a shop with a lift and all that stuff but he said hes never worked on toyotas much.
    I just use the stock springs on my truck right do i need to think about getting any special tools or is it a pretty straight foward install.
    Sorry guys 1st truck always had sports cars if u cant tell. lol
  2. Jun 11, 2009 at 8:12 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I don't think you should add the spacer and the 5100s. If you want more then 2.5 you should get different coil overs or coil springs.
    You use the stock coil springs with the 5100s if you want. Or to get full 3" lift, you should get OME 886 springs and set the 5100s at the stock setting.
    The only special tool needed is a spring/strut compressor.
