billys at 2.5 w/ 1" bodylift
Discussion in 'Suspension' started by enjm10, Mar 15, 2011.
  1. Mar 15, 2011 at 8:04 PM
    enjm10
    enjm10 [OP] Well-Known Member
    Eric
    NM
    07 V6 4x4 Silver Streak
    20% tint all around, 5100s all four corners w rear aal, step bars, windshield visors, foglight anytime mod, front black lip, door emblems blacked out, satoshi grill, avid light bar, dash light mod blue, also did my own stereo led mod
    Anyone running the Billy's at 2.5 w a 1" bodylift? If so post pics wondering what it'd look like I know body lifts are normally a bad idea but figured a 1" wouldn't be all that bad
  2. Mar 15, 2011 at 10:03 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    I don't think I've ever seen anyone on here with that setup. What size tires are you trying to fit with that combo?
  3. Mar 16, 2011 at 6:36 AM
    enjm10
    Eric
    NM
    I'm currently running 265/70/17 bfg at with the bilsteins at 2.5 I was just wondering if it'd be a good idea and be able to fit 285 without the considerable trimming and also c what it looks like with 265
  4. Mar 16, 2011 at 6:41 AM
    KPT
    09 Prerunner
    Fair enough.
    If you want to gain a small amount of clearance for those 285's, you could run a thin top plate spacer on top of the billies to get you from 2.5" to a full 3" of lift. Just saying it's an option.
  5. Mar 16, 2011 at 11:08 AM
    enjm10
    Eric
    NM
    with the 1/4" top plate spacer on each strut?? And also I don't wanna have to get into buying aftermarket ucas a lot of cash to dish out on something like that even tho it'd be worth it but with the 1/4" top plate spacer on the billys at 2.5 would u need the new Lucas?
  6. Mar 16, 2011 at 12:14 PM
    KPT
    09 Prerunner
    Yes you likely would @ 3"....you may even need new UCA's at 2.5" of lift...some do, some don't
  7. Mar 17, 2011 at 12:21 PM
    enjm10
    Eric
    NM
    Ok all the angles looked good after I had my billys installed awhile back, I still would like to know if the body lift would look good or not
  8. Mar 17, 2011 at 1:27 PM
    KPT
    09 Prerunner
    The overwhelming answer on here will be no.
    But it doesn't matter what we think, it's whether you like it or not.
  9. Mar 17, 2011 at 7:11 PM
    enjm10
    Eric
    NM
    Yeah I have always read into a lot of threads just never really posted but I know the majority here do not like body lifts n with eibach and the billys set at .85 would give me just a bit more lift then I'm getting out of the 5100s set at 2.5 and would u suggest aftermarket ucas with the eibach or so some ppl get by w/o em
  10. Mar 17, 2011 at 7:16 PM
    KPT
    09 Prerunner
    The eibachs give 1.6" of lift..
    0.85+1.6 = 2.45", so the eibachs will not give you more lift than the billy's at 2.5".
    At 2.5", it's hit or miss with UCA's.
  11. Mar 17, 2011 at 7:18 PM
    enjm10
    Eric
    NM
    I want to get more lift but don't have that much cash to put out I really like the looks of the 4.5" rcd but for that price out of the question
  12. Mar 17, 2011 at 7:18 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    A 1" body lift wouldn't look bad with gap guards
  13. Mar 17, 2011 at 7:22 PM
    KPT
    09 Prerunner
    I would actually prefer a 3" suspension + body lift over a drop bracket lift like the RCD.
  14. Mar 17, 2011 at 7:26 PM
    enjm10
    Eric
    NM
    Really? Y? And any input on the durability of the body lift 4crawler.com has for sale, anyone?
  15. Mar 17, 2011 at 7:28 PM
    KPT
    09 Prerunner
    Drop brackets lower your ground clearance.
  16. Mar 17, 2011 at 7:38 PM
    enjm10
    Eric
    NM
    I thought u were gonna say like the integrity of em was bad I think they r a little too pricey
  17. Mar 17, 2011 at 7:40 PM
    KPT
    09 Prerunner
    Unless you get a big enough one to fit 35's, there's just no point of them IMO. You can already fit 33's with a 3" lift. So if you run 33's with a 4.5" DB (which I do not believe you can fit 35's on), then you actually lose ground clearance. So they are just for looks IMO.
  18. Mar 17, 2011 at 7:44 PM
    enjm10
    Eric
    NM
    Yeah that's true exactly y I was thinking of going the cheaper way by just sticking w my 5100s and c bout adding a 1" body lift.
    How hard is it to install a bl any idea or better to have a shop do it
  19. Mar 17, 2011 at 7:48 PM
    KPT
    09 Prerunner
    That's a 3" though....might even be a 4 actually the front fenders look really high to me.
  20. Mar 17, 2011 at 7:52 PM
    enjm10
    Eric
    NM
    It seems to be a full on 3" body lift tho I would be going with a 1" so it wouldn't show that bad I would think but I am not very sure that's y I am asking for opinions on it n I do know everyone here disagrees w a body lift
