billys w/881 help
Discussion in '1st Gen. Tacomas (1995-2004)' started by kyle39, Aug 30, 2010.
  1. Aug 30, 2010 at 1:43 PM
    kyle39
    kyle39 [OP] Reppin' BC
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Deck plate mod, rhino lined, A.r.e. flush glass shell, 265/75/16 Duratrac's, MB72 rims, Full OME lift, Dakars in the rear, Tint allround
    If i get the the ome 881 coils w/ billys 5100 and Lr uca's, what would be a good height for the billys? i hear the 881 give you bout 1.5" of lift from stock, i also heard that maxing out the billys will wear faster? is any of this true:confused:.
    I want about 2.5" of lift, what would be the best was to achieve this?
  2. Aug 30, 2010 at 1:56 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    pairing the 5100's with 881's is better (both in ride quality and wear/tear on the shocks and coils) if you're leaving the shocks on '0'. if you want to max out the shocks you'll be better off to get different coils, the 881's are too long and too heavy to work in that situation. My 5100's were installed (by accident, long story, not my fault) at the highest setting with the 881's and the ride was rougher than hell. Once I dropped the 5100's to '0' all was good. FWIW the front end of my truck gained about 3.5" before I had the shocks brought down to '0', now its about 2" and the ride is comfortable.
  3. Aug 30, 2010 at 2:00 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    i have the same lift kit too, but my truck is a 4 banger so it will give my truck close to 3" since your truck is also a 1st gen and a v6 you can get 2" to 2.5". yes you can set the shock up to 2.5 but it can stiffen the ride. there's another way you can add a little lift to using the 10 mm enhancer plate.
    http://wheelersoffroad.com/ometaco.htm
  4. Aug 30, 2010 at 2:16 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I have Bilstiens set to 0 with 881 coils and before the AAL it raised it 2" then after the AAL which raised the rear 1.5 the front droped about 1/2 " the ride is great.
  5. Aug 30, 2010 at 2:28 PM
    kyle39
    Kyle
    Vancouver BC
    04 Tacoma Trd
    if the billys are set to the middle setting, is that going to make the ride stiffer with the 881, is there other coils available that wont do this:confused:
  6. Aug 30, 2010 at 2:38 PM
    kyle39
    Kyle
    Vancouver BC
    04 Tacoma Trd
    What if i use my stock springs, i have 81,xxx m. how fast would they wear out, or would it just be worth it to grab new ones since ill have to take everything apart n.eways. would i then have them near the top setting to get 2.5 in.
  7. Aug 30, 2010 at 3:57 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    I have 880s on stock shocks and I got about 1.5'' with a 4cyl and extra cab, I would say put your 881s on the 5100s set to 0 and see what you get. The OME springs work better with aftermarket shocks so definetly keep the 5100s...And you will get a better ride with the 881s on the 5100s set at 0 than with stock springs and the 5100s set higher.
  8. Aug 30, 2010 at 3:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    881's and billy 5100's on my double cab gave me 2 inches of lift...the billies were left on the stock/bottom setting. its not a good idea to preload the ome coils.
  9. Aug 30, 2010 at 4:06 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    The adjustable 5100s were designed specifically to be able to level the Toyota OEM progressive coils. The higher you adjust, the stiffer the ride. They were not designed to lift the much stronger, non-progressive OME (or I suppose Eibach, or whatever) coils, where it is the coild spring itself that provides the lift. The Billies can be used with these springs, but should be set at zero, and used as a normal shock, which works great.
    The 880, 881, 882s are each 10 mm taller than the previous (881 = 880+10mm). That is the only difference.
