Bilstein 4600 front strut top nut size
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DKH, May 6, 2024.
  1. May 6, 2024 at 12:17 PM
    DKH
    DKH [OP] Member
    Hi all,
    I know I'll get roasted, but I did try to search for it and I can't seem to find the nut size for the front struts for the Bilstein 4600. Reason I ask is I have a 2016 SR, took out the old Hitachi's, trying to put in some used Bilstein 4600, but they didn't give me the top nut. I'm trying to use the old nut from the Hitachi, but the fit just doesn't seem to be right... a little too tight for comfort. Anyone have any ideas/hints? I really appreciate it. Otherwise I'm out of a truck and need for figure some shit out.
  2. May 6, 2024 at 12:31 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Are you referring to the aftermarket Bilstein 4600 or the OEM TRD Offroad Bilstein? By several accounts they are different.
    In any case, you should be able to measured the diameter and thread pitch and grab a nut at the hardware or autoparts store. They often have the necessary measuring tools at the store.
  3. May 6, 2024 at 12:31 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I did a search and came up with several hits, from 4R to BMW (guess they still call em bimmers o_O)
    I am not saying it's right though.
    "It’s a 19mm for Bilstein unlike OEM which is 17mm"
  4. May 6, 2024 at 12:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are you talking about the 3 nuts that mount the shock to the frame?
    Or the 1 big nut on top in the center?
    The smaller are m10x1.25
    The the big one is m12 ( likely 1.25 also)
    At least that is what they are on the stock Bilstein shocks
  5. May 6, 2024 at 1:00 PM
    DKH
    DKH [OP] Member
    Thanks everyone, I'm referring to the OEM ones, the guy I bought it from took it off of his TRD Off Road. I'm reffering to the 1 big nut on top. Using the "lowering lower control arm to release tension" technique, so didn't remove the 3 nuts for the whole assembly.
  6. May 6, 2024 at 2:28 PM
    TnShooter
    Deogee
    STOCK
    Pretty sure its an M12
    Also, it is a lock nut. It is not a regular nut.
  7. May 6, 2024 at 10:13 PM
    DKH
    DKH [OP] Member
    Thanks again everyone. Confirmed it’s a M12, but the key is the pitch - 1.25. I had 1.75….
    and thanks for educating me regarding the difference between the off road bilsteins and the 4600. What a noob
    TnShooter likes this.
