Bilstein 4600 vs Bilstein 5100 vs Rancho RS5000 on Stock 08
Discussion in 'Suspension' started by Sboattaco, Oct 17, 2014.
  1. Oct 17, 2014 at 11:08 AM
    Sboattaco
    Sboattaco [OP] Member
    Colorado
    09 SR5 4x4 Long Bed
    My first post, so please take it easy on the rookie . . . I have a 2008 SR5 double cab long bed with 95k on it . .the front stock (tokitco) shocks have never been replaced (rear have been a few years ago) . .but I am getting new 265/75r16 Cooper At3 tires in a couple weeks and also some new TRD 16 black alloy FJ rims . . . so I thought it might be wise to replace the shocks at the same time. I do not plan on lifting it at this time . . .From digging through these threads most are focused on lift kits, etc . . and I am honestly not too educated on this stuff . . but my research is showing 3 options floating to the top of my decision tree . . Bilstein 4600 or Bilstein 5100 (would I set these at zero/o . . or could I raise them a bit? with no lift kit) . . or the guy at Autoanything was telling me to go with RanchoRS5000?
    Any suggestions or help would be greatly appreciated
  2. Oct 17, 2014 at 11:18 AM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Avoid Rancho rs5000. If you want Rancho, go with the 9000 series. Bilsteins are good, however when I had 5100s they leaked at about 40k. Maybe KYB if you want stock height. Cheaper and are as good a bilsteins in my opinion. They're a Japanese brand.
  3. Oct 17, 2014 at 11:22 AM
    520Toyota
    C.V.
    Nor Cal
    Ome lift
    Just to add, I've installed them on two 1st gent tacomas, two 3rd gen 4runners and 2nd set on my 01 corolla that has 390k.
  4. Oct 17, 2014 at 11:49 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I have run the Rancho RS5000 on my other trucks and had no problems and they rode great. I now have the Bilstein 5100's all around. They are a great shock. I have had my rears leak and replaced under warranty. I have my front set at 0 with the OME 883x coil springs and it rides so much better then stock. It did raise me about 1 1/2in. to level it out nicely. I am vary happy with them providing I don't have any more leak issues. If I have any more issues with the rears leaking I MAY put the Ranchos on the rears .
  5. Oct 17, 2014 at 12:03 PM
    el topu
    el topu Well-Known Member
    Juan
    SLC, Ut
    Tundra Limited CM TRD Off-road
    I got Bilstein 5100 all around, no issues and the side is better then stock shocks
  6. Oct 17, 2014 at 12:10 PM
    Sboattaco
    Colorado
    09 SR5 4x4 Long Bed
    Thanks for the updates . . . and your truck is Not lifted correct? So did you have to set the rear bilsteins at certain setting (or zero as well)
  7. Oct 17, 2014 at 12:11 PM
    Sboattaco
    Colorado
    09 SR5 4x4 Long Bed
    do you remember what you set the front and rear 5100 shocks at to make it level?
  8. Oct 17, 2014 at 12:11 PM
    Sboattaco
    Colorado
    09 SR5 4x4 Long Bed
    Thanks - -I will check those out as well.
  9. Oct 17, 2014 at 12:19 PM
    tacoma guy
    Joe
    Phoenix Az.
    No lift just leveled the front . With the Bilsteins there is no adjustment in the rear.
  10. Oct 17, 2014 at 12:27 PM
    el topu
    Juan
    SLC, Ut
    I have them on the 1.75" lift (second from top to bottom)
  11. Oct 18, 2014 at 9:26 AM
    Sboattaco
    Colorado
    09 SR5 4x4 Long Bed
    Are the OME 883x coils slightly longer than than the stock coils then?
  12. Oct 18, 2014 at 11:46 AM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Youll want to go with either the 4600 or the 5100 Bilsteins, or maybe even Fox 2.0. Id avoid the Rancho 5000s and any shop suggesting them ;)
    The 4600 Bilstein is the yellow shock and offers no lift options. It rides a little tighter than the 5100 on road.
    The 5100 Bilstein is a zinc coated shock with a few optional height settings. I would suggest putting it on one level up from the bottom, it will give you less than 1" of lift but provides the best ride.
    The FOX 2.0 is a shock that is similarly sized to the Bilstein, but comes as a complete assembled package with new springs, as well as having a threaded coilover body that allows you to dial in the height from 0-3"
    Let me know if I can be of any help, we stock all of these options for the Tacoma and have had great results with them.
  13. Oct 18, 2014 at 12:12 PM
    tacoma guy
    Joe
    Phoenix Az.
    Yes they are. They will level out your truck with out reloading your springs. That is why you set the Bilsteins to 0. They give you a great ride.
  14. Oct 20, 2014 at 10:25 AM
    Sboattaco
    Colorado
    09 SR5 4x4 Long Bed
    thanks . . what is your website?
  15. Oct 20, 2014 at 12:37 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
  16. Oct 20, 2014 at 1:02 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    " preloading "
  17. May 20, 2015 at 3:02 PM
    Charlot
    Charlot Well-Known Member
    Ontario, Canada
    Tacoma TRD 2018 Upgraded
    This is getting me confused,or still undecided on my choice of new shocks.
    At first i was just going for KYB,then Monroes,then Bilstein Bilstein,and a Bilstein 4600
    In my area,no ones ,even Toyota Dealers will not install exceot there original ones,and the other garages will put only there Napa Monroes and KYB
    So don know anymore,,
  18. May 21, 2015 at 3:09 PM
    Charlot
    Ontario, Canada
    Update.
    I found another Toyota Dealer,not far from my home that will install whatever i want.
    So i will go probably Bilstein 5100 or Bilstein 4600
    Not sure yet
  19. May 21, 2015 at 9:21 PM
    el topu
    Juan
    SLC, Ut
    Go with 5100 the ride is a lot better
