Bilstein 4600
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnm2491, Sep 9, 2016.
  1. Sep 13, 2016 at 11:29 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    I have heard the hitachi's are firm and this is why i am wondering if I should use my 2015 TRD sport shocks with 2016 sport springs.
  2. Sep 13, 2016 at 7:16 PM
    Johnm2491
    Johnm2491 [OP] Well-Known Member
    2024 TRD Off Road DCSB
    Frigg-off Barb
    I can use my old springs with the 5100's? theres a little over $100 difference between the 4600's i found and the 5100's.
  3. Sep 13, 2016 at 7:36 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Yes
  4. Sep 13, 2016 at 7:59 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I had originally gone with 5100s on all 4 corners. Front are set at 0 matched up with OME 883 coils to level out the truck . Rear is stock higth. After two sets of 5100s leaking in the rear I decided to go with the 4600hd no more leaking . I be leave the 5100s are meant for a lifted and being my rear was not that's what caused them to leak . The 4600hd ride just as good as the 5100s . Hope that helps !
  5. Sep 13, 2016 at 10:34 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    Lifetime warranty regarding what? Leaking oil seals and worn out bushings?
  6. Sep 14, 2016 at 5:57 AM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    OP, just keep in mind that swapping out the shocks won't help with sagging at all. Ride height is determined by the springs so while you may want a smoother ride with new shocks that will still leave you sagging in the front end
  7. Sep 14, 2016 at 6:41 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Gonna get my soap box out for a minute.... This doesn't apply to anyone in this thread, just a bit of commentary on suspensions in general....
    I spent a few years as a suspension tech for Honda, albeit on dirt bikes. Applying what I learned there to trucks isn't as much of a stretch as you might imagine.
    Suspension and ride quality is a combination of ALL components, likely no better as a whole than the weakest link. Coils/springs/leaf's support weight while allowing flex. When you compress a spring, it naturally want's to return to it's original length/height. That comes with the release of stored energy called rebound. There is the most under-rated difference in what most shocks can and will do for suspension. Without proper rebound dampening, you get a "jackhammer effect" AFTER the bump is encountered. Shocks dampen the compression, and dampen the rebound. A given shock absorber will react differently to varied spring rates, varied weight of vehicles, and varied speeds at which the suspension is impacting "bumps". So there is a different reaction to impact, then a different reaction on rebound, based on speed, weight, and spring rate.....Tires also effect the suspension characteristics. Most commercially available non adjustable shocks are designed to work in a range that covers "average" spring rates, "average" vehicle weights, and speeds up to what is normally seen of highway driving.
    Suspension geometry can (and does) effect ride quality to a great extent.....not just handling/steering. Components such as control arms, sway bars, spindles, hubs, wheels, etc, can make even the best coils/shocks perform better or worse. Poor geometry can result in a vehicle that handles "nervous", which can effect the way shocks perform. By the same token, bad shocks can cause that same nervousness, which makes for an ill handling vehicle. Long story short there, even the best shocks on earth can't correct an evil handling vehicle with improper geometry.
    Another very important factor is production cost....of the shock.....and of the vehicle as a whole. In spite of the old saying, you don't ALWAYS "get what you pay for". But, cheaper, lower end shocks probably won't perform at the levels of higher end, higher priced shock when pushed to (or beyond) their limits. This is a broad strokes generality, as opposed to a carved in stone "fact" though.... Price doesn't always determine the level of quality...
    There's "good", then there's "good enough".....How "good" do you need? Some very high dollar components developed for racing will deliver far more performance capabilities than a low priced OEM "replacement" component. Question is, do you ever need the added performance they're capable of delivering? Do you ever push your suspension beyond the safe limits of that low end or mid range quality component?
    IMHO, the vast majority of suspension component buyers are purchasing beyond their actual needs. (in the name of status?) Nothing WRONG with that. Just that it's a matter of choice rather than a matter of need. With that said, overkill is usually better than "underkill"....
    In short, it takes a sense of balance between all the components to make a vehicle ride and handle well. Just throwing one high dollar component at an otherwise "mediocre" suspension won't correct it's ills.
    Currygoat, landphil, TXpro4X4 and 2 others like this.
  8. Sep 14, 2016 at 7:32 AM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Good info thx
  9. Sep 14, 2016 at 7:37 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    @Bluegrass Taco I have read here on TW that the 15 and 16 springs are the same length but the 16 spring gives 2nd gens an inch lift. As I understand it the spring rate is adding the lift. Do you think OEM 2015 Sport Billys will be ok if joined with 2016 Sport Springs? My concern is that the 2015 billys aren't valved correctly for the additional spring rate? Not really looking for technical data just an opinion.
  10. Sep 14, 2016 at 7:45 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Not sure I have enough data at this point to form an opinion on that. Do you know the spring rate on the 2016 coils? Just a knee jerk reaction, they SHOULD be OK....But that's strictly a guess on my part
  11. Sep 14, 2016 at 10:36 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    717 per toytec.
  12. Sep 14, 2016 at 10:49 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    That is WAY stiff of a spring rate for a 4600 shock. OME 886's are 660lb rate and are considered too stiff for 4600's or 5100's....and therefor not recommended.
    If those numbers are correct, that spring would overwork the rebound dampening on a 4600 or 5100 with valving for a gen 2 Tacoma. I've been hearing Bilstein is issuing a new part # for the 2016 shocks.....Maybe this being the reason why?
  13. Sep 14, 2016 at 10:51 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I better bolt up the Hitachi's!
  14. Sep 14, 2016 at 3:04 PM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    I called Bilstein two weeks ago and they were still in R&D for the 2016 shocks. No help!
  15. Sep 15, 2016 at 8:15 AM
    #35
    NewRider
    Travis
    '87 4runner
  16. Sep 15, 2016 at 10:58 AM
    #36
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    @TOYTEC I have read your thread on lifting a 2016 and i am wondering if i put a 2016 sport suspension on a 2015 will it be ok?
  17. May 18, 2017 at 11:28 AM
    #37
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    watching a video on the US bilstein plant where they make bilsteins and they show the monotube versions like we all know (4600, 5100 etc) but some of them they where assembling where twin tube low pressure shock.
    it it possible the stock TRD/toyota bilsteins are actually not the the monotube but are instead the low pressure twin tube? And the twin tube where much thinner than the monotube , just like the toyota bilsteins are thinner than the 4600 Hd's.
    Anyone ever taken apart the toyota bilsteins??
