Bilstein 4600s on rear & 5100s on front ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MexiCat, Aug 29, 2023.
  1. Aug 29, 2023 at 10:11 PM
    MexiCat
    MexiCat [OP] Member
    Puerto Escondido, Mexico
    2014 TRD Sport
    Question: Is it lunacy to place a set of 5100's (set at the first incremental raised height setting) without changing out Springs ...... in order to improve the rake angle (vs putting spacers on)? If so, would it hurt to put 4600's on the rear (understand that the 4600's ride a bit smoother than the 5100's). I know that the rake angle won't be totally eliminated in that scenario ..... but I am assuming that it will be slightly improved over stock. Again, does placing the 5100 at the first incremental raised height require any other changeout (ex. replacing OEM Coilovers) ?
  2. Aug 29, 2023 at 10:30 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    You can retain your OEM spring at whatever clip you use.
    OEM 4600 is a bit crap than running 5100.
    I would just spend on the 5100 or 5160 in rear.
  3. Aug 29, 2023 at 10:35 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Sure, why not? OP, you can def put stock coil springs on 5100’s to raise up the front a bit
  4. Aug 29, 2023 at 10:40 PM
    MexiCat
    MexiCat [OP] Member
    2014 TRD Sport
    I was planning on purchasing new 4600s for the rear ....... vs. the pre-existing OEM rear shocks. So new 5100 adjustable(s) on the front ..... new 4600s on the rear.
    BlkDakDave likes this.
  5. Aug 30, 2023 at 6:31 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    OEM shocks are not bilstein 4600s. FYI.
