Bilstein 4600's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CoMo Taco, Mar 30, 2021.
  1. Mar 30, 2021 at 1:54 PM
    CoMo Taco
    CoMo Taco [OP] Well-Known Member
    Judah
    Columbia, Missouri
    2018 Toyota Tacoma SR Access Cab 4x4
    Alpine stereo replacement, 6x9 Kicker front door speaker upgrade, Kicker tweeter upgrade. 6000k HID upgrade, Running boards installed, Rear seats installed, Pedal Commander, Meso Map Lights, TRD pro grille, Raptor lights, TRD Pro rims, 4600's Bilsteins, Diode Dynamics SAE Yellow Fog lights, Custom fuse box.
    I am planning on putting on Bilstein 4600's onto my 2018 Toyota Tacoma SR. I have shocks and springs but no mounting hardware. Can/should I use my OEM stock hardware. If I should buy it I am not too sure where to buy it any help would be appreciated.
  2. Mar 30, 2021 at 3:29 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Should be able to use your existing hardware. I can’t imagine they use different hardware for sport, off-road and sr/sr5
  3. Mar 30, 2021 at 3:42 PM
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    Just to be clear, since this confusion comes up alot, but you're using the Aftermarket 4600's and not the OEM TRD Off Road shocks, right?
    Regardless, you should be able to use OEM stuff. The 4600 is meant to be an OE replacement shock.
  4. Mar 31, 2021 at 5:38 AM
    CoMo Taco
    Judah
    Columbia, Missouri
    It is actually the OEM TRD Off Road shocks
    71tattooguy likes this.
  5. Mar 31, 2021 at 7:39 AM
    Snaeper
    Martin
    Phoenix, AZ
    OEM hardware should definitely work.
    Just to clarify in the future though, the 4600 is unrelated to the TRD Off Road shocks. Only things they have in common are the paint job. 4600 is more closely related to the 5100.
    Scott4032 likes this.
