Bilstein 5100´s
Discussion in 'Suspension' started by mchon, Oct 26, 2009.
  1. Oct 26, 2009 at 11:03 AM
    mchon
    mchon [OP] Member
    Los Angeles
    00´ Prerunner SR5
    BFG All Terrain 31X10.5 R15, Hella 500´s, Front Lightbar, Raptor Liner, Bilstein 5100 F&R.
    Hey i just got the 5100´s all around for my 2000 tacoma set the front at the higuest ring but it feels hard...i wanted to level out the truck and it looks good cuz its higher in the front do any of you know how the different ring measurements on the front 5100´s work? when i got them they were set to the middle height ...dont know if this is the right heigh to level it out and i screwed up going one higher or what? any comment is greatly appreciated.
  2. Oct 26, 2009 at 11:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The notches represent the different eights:
    First (lowest) = Stock
    Second = .85" lift
    Third = 1.75" lift
    Fourth = 2.5" lift
    The more you preload a spring, the more firm it will ride, thus at the highest setting, the ride will be more firm than stock.
  3. Oct 26, 2009 at 1:10 PM
    mchon
    mchon [OP] Member
    Los Angeles
    00´ Prerunner SR5
    Wow...alright thanx a lot...i´ll get that done then! humm...what would be the correct setting to have a confortable ride...yet have it level out?
  4. Oct 26, 2009 at 1:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think the 1.75" setting gets it close to level
  5. Oct 26, 2009 at 2:19 PM
    mchon
    mchon [OP] Member
    Los Angeles
    00´ Prerunner SR5
    Great!..Ok Thanx =)
  6. Oct 27, 2009 at 7:22 AM
    Casper_k77
    Casper_k77 New Member
    Latvia
    06 PreRunner SR5 2WD
    Need your help and advise!
    I just got imported to Europe -Tacoma '06 PreRunner SR5 2WD Double Cab. Unfortunatly here in Europe we do not have Tacomas on the market that is why I can't get advice here.
    I am not sure what suspension is on my truck now ? The sticker on the side of the bed says TRD Off Road ? I am not sure cause shocks are not bilstein blue/yelow but shocks are black and I do not have alloy wheels, 115V/400-watt deck mounted power outlet, multi-function overhead console with compass and temperature gauge, engine skid plate? I am suspecting that it is stock regular suspension and somebody puted sticker on to show-off.
    Now my rear Left rear shock leaked out so it got to be replaced. I want to replace all 4 shocks on to 5100 bilstein. I want to have comfortable ride, cause my previouse ride was Chrylser 300C. I want to have smooth and comfortable ride. I am not doing any crazy off-roading .I am using my truck on street in the city mostly and and wods(hunting), gravel roads for transporting my four wheeler(Suzuki LTZ400). I am not using truck to carry really havy loads on daily basic. What would you suggest ?
