Bilstein 5100’s install Question
Discussion in 'Suspension' started by TheFactor, Aug 16, 2023.
  1. Aug 16, 2023 at 7:43 AM
    TheFactor
    TheFactor [OP] Well-Known Member
    So Cal
    2023 Tacoma TRD Off road
    My local 4wd toy store is installing some 5100’s next week and was wondering what line on the shock should be used to get it leveled ? I definitely don't want the front end sitting to high. Also whats the biggest tires I can run with just having it leveled and that will look good and still have a nice wheel well gap? I know with bigger tires probably some trimming and loosing the front mud flaps will have to happen I’m guessing.I don’t have front cameras except for active cruise and maybe collision alert will it throw things off being an inch or two higher?
    Any other advice will be much appreciated and thanks in advance.
  2. Aug 16, 2023 at 7:57 AM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
  3. Aug 16, 2023 at 8:00 AM
    TheFactor
    So Cal
  4. Aug 16, 2023 at 8:02 AM
    Merling
    James
    NH
    Also measure your distances before so you can compare after. I did not when getting work done similarly and regret that one pretty bad
    TheFactor[QUOTED][OP] likes this.
  5. Aug 16, 2023 at 9:48 AM
    TheFactor
    So Cal
    Great advice !
    Should I measure from center cap of the wheel to the bottom edge of the fender or ground up to the bottom fender edge?
  6. Aug 16, 2023 at 9:57 AM
    Merling
    James
    NH
    I think most people do from center cap, so if you change wheels or tires later it’s more or less the same
  7. Aug 16, 2023 at 10:00 AM
    BTL Y-Wing
    BTL Y-Wing Well-Known Member
    2020 Army Green TRD Pro
    I'd say have the rear end slightly higher than the front so it'll level fully when a bit of weight is added. When my truck was leveled with no load it didn't take much to make the back end look saggy, whereas with an extra 0.5-0.75" added to the back above level the rake is hardly visible when unloaded and with my normal weight when offroading it comes to just about level.
    TheFactor[OP] likes this.
  8. Aug 16, 2023 at 10:08 AM
    TheFactor
    So Cal
    Thanks and good idea :thumbsup:
    Thanks that makes sense .
  9. Aug 18, 2023 at 8:09 AM
    JS11B
    JS11B Member
    '23 TRD OR
    I just installed Bilstein 5100s & only wanted it level, they put the clip on the 3rd notch (1.1") After the install the front was slightly higher, but It did settle a little & now the front is slightly lower. I think this varies slightly from truck to truck. There is also "taco lean" but only 1/2" IN THE REAR & that isn't an issue for me.
    hope this helps
  10. Aug 18, 2023 at 2:05 PM
    TheFactor
    So Cal
    Awesome thanks for you help !
    How’s the ride compared to stock ?
    JS11B[QUOTED] likes this.
  11. Aug 18, 2023 at 6:17 PM
    JS11B
    JS11B Member
    '23 TRD OR
    no problem, glad I can contribute
    90% of my driving is on the road & mostly freeway. It's 100 X better than stock; OEM shocks felt like a boat pitching & listing on the freeway. Truck feels more planted with 5100s & less body roll etc.
    I had OEM Bilsteins on my old Nissan NISMO for 19 years & they didn't feel as weak as the OEM Taco ones.
    Also I have an OTT tune, when I would get on it I could feel some axle wrap w the OEM suspension; w the 5100 that went away, there's no flex.
  12. Aug 18, 2023 at 8:23 PM
    TheFactor
    So Cal
    Oh man that’s great to hear! I’m getting mine installed next week. I went ahead and ordered some matching ones for the rear. Im on the fence but I’m thinking about going all in with some 33” Mickey Thompsons Baja AT. It’s a tough decision but regardless now I’m really excited to get these 5100’s on. Definitely going to get the OTT just waiting to see if I go with 33’s so they can tune it accordingly for my setup.
    Thanks brother for inspiring input
