Bilstein 5100 & 2" aal??
Discussion in '1st Gen. Tacomas (1995-2004)' started by TeamRooR, Nov 1, 2010.
  1. Nov 1, 2010 at 8:01 PM
    TeamRooR
    TeamRooR [OP] Well-Known Member
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    I have seen this setup favored by a few on here but wanted to hear any recommendations/tips you all would be so kind to throw out there... I am currently having my frame swapped and figured why not, there is a 2-4 week wait...
    I have 265/75/16 BFG AT and rub every so slightly, don't want to spend an awful lot of money, need new shocks/struts, drive 60-200 HW miles daily but also find myself on a lot of log roads.
    Do the 5100's and a 2" add a leaf make the most sense for my needs??
    What would be the ideal settings?
    Wheres the best place to buy the (1.5 or 2"???) add a leaf, 5100's, bushing kit and diff. drop kit. Looking for a good deal but good service is a must. (Toytec seems to have all of those items in stock...)
    Thanks!
  2. Nov 1, 2010 at 8:43 PM
    Tonka Tacoma
    Tonka Tacoma Well-Known Member
    Eric
    Plattsburgh, New York
    2009 Regular Cab 4X4
    3'' Toytec Suspension Lift, Dick Cepek DC-2 Rims, BF Goodrich All Terrain TA's, Bug Guard, Side Window Visors, Back Window Visor, Diamond Plate Kobalt Tool Box, Stainless Steel Exhaust Tip, Stainless Steel Plate Frames, Stainless Steel Stubby Antenna, "TACOMA" Front Windshield Banner, Toyota Tundra 4X4 Tailgate Badge, And TRD Box decals.
    I just orderd everything to do a 3" lift from Toytec. I did some homework, and from what I understand, Toytec's AAL, bushing kits, and differential drop are decent quality products. The prices are fair as well. I ordered everything one would need to do a nice 3" lift, but even after tons of research, I am not sure how necessary the diff. drop is. Does 3" realy change the angle of your CV's enough to cause damage? Who knows, these are the questions that keep me up at night! Haha If anyone knows how beneficial the diff. drop is, please chime in!
  3. Nov 1, 2010 at 8:56 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I have the 5100's with the Eibach coils and a 2" AAL and I love the ride. I also got the Diff drop kit and my angles are pretty good they were a little steeper with out it I would buy it again just to be sure.
    Check out my build if you want to see how the 5100's look.
  4. Nov 2, 2010 at 6:06 PM
    TeamRooR
    Phil
    Hedgesville, WV
    2003 Tacoma TRD 4x4
    K&N intake, rust
    anyone have anything to say about just the 5100's and aal?? is that not the way to go?
  5. Nov 2, 2010 at 7:15 PM
    SlimDigg
    SlimDigg Resident MMA Fanatic
    Calgary, AB
    2001 TRD Double Cab Limited 4x4
    OME 881, Bilstein 5100, Icon AAL, Wheelers Anti-Sway kit, aFe Pro Dry-S Air Filter, Deck Plate Mod, Rear Diff Breather Mod, GE Nighthawk Platinum headlights, Wet Okole Seat Covers, Husky Liners. LED Tail Lights
    my frame is being swapped as well.
    So i picked up 5100's all around, ome881 front coils, and this for the rear:
    http://www.iconvehicledynamics.com/store/products.php?product=96%252d-Current-Tacoma-{47}-2000-%252d-2006-Tundra-Rear-Add-a-Leaf-Kit
    My guy said it would be a way nicer ride than the wheelers single leaf I was originally looking at.
  6. Nov 10, 2010 at 6:40 AM
    jdcrowe75
    jdcrowe75 Well-Known Member
    North Florida
    2010 DC TRD OR 4x4
    I've got 5100s at 2 1/2" setting with TSB rear and 1 1/2 rear blocks. Love the ride. I tried TSB rear with 1 1/2" AAL but was too stiff for me. I had to add driveshaft carrier bearing drop to eliminate vibration. Got my 5100s from Down South and everything else from Toytech. BUT, I'm a 2nd Gen. :)
  7. Nov 10, 2010 at 6:57 AM
    Gooch814
    Gooch814 Well-Known Member
    Jeff
    Sumter SC
    04 Prerunner SR5
    5100's all around, Toytec coils, 2inch AAL. Deckplate mod. Westin Nerf Bars.
    I had my 5100's and 2" AAl delivered and was abou to pull the trigger but I decided to pony up a few more bucks and get the Eibach coils like JLee did(Above post). My reasoning for the coils was I did nto want to sacrifice the slightest ride downgrade for height. Set my billies at 0" and threw everything on.
    I am thrilled with the height and the ride is great. It's of course up to you but your current setup should be fine.
  8. Nov 12, 2010 at 12:58 PM
    taco man31
    taco man31 Well-Known Member
    pics please
  9. Nov 12, 2010 at 3:55 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    You guys with the 3" coils, how was the alignment? Any issues?
