Bilstein 5100 3inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TanzTacoma, Mar 1, 2020.
  1. Mar 1, 2020 at 11:01 AM
    TanzTacoma
    TanzTacoma [OP] Well-Known Member
    Tanner
    Boise, Idaho
    2009 TRD Sport Tacoma
    Going to go with a lift in the next 2 weeks just because this one is budget friendly, I just have a few questions on it if if anyone is running this
  2. Mar 1, 2020 at 11:04 AM
    doorsidedown
    doorsidedown Well-Known Member
  3. Mar 1, 2020 at 11:05 AM
    TanzTacoma
    Tanner
    Boise, Idaho
  4. Mar 1, 2020 at 11:13 AM
    doorsidedown
    I ran something very similar on my last tacoma. Only difference was coil springs. Did very well for me.
    Casper66 and TanzTacoma[OP] like this.
  5. Mar 1, 2020 at 11:15 AM
    TanzTacoma
    Tanner
    Boise, Idaho
    I know they are recommended but not always required but did you run new UCA’s with it? I’m thinking of getting it as is then in a month or 2 adding new UCA’s. What size tires did you run with it?
  6. Mar 1, 2020 at 11:17 AM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Run new UCA’s when you buy it. Easier to do it all at once.
    Buy JBA or SPC
  7. Mar 1, 2020 at 11:19 AM
    doorsidedown
    I did put new UCAs on. I did it all at one time. Freedom Offroad makes a good budget friendly UCA at $360.
  8. Mar 1, 2020 at 1:06 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    I'm running 5100's with the stock springs on the front and I got 2.5 out of it. Rides great and I'm super happy with them. I went with ome Dakar springs on the back. What tire size are you going with?
  9. Mar 1, 2020 at 1:21 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Either 275/70/17 or I really wanna go 285/75/17
  10. Mar 1, 2020 at 1:29 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    I ran 285's with a 3" and stock UCA's. You should have plenty of room.
    TanzTacoma[OP] likes this.
  11. Mar 1, 2020 at 1:30 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Whaaatt! Awesome to hear, makes me happy lmao. I’m no suspension expert whatsoever so I appreciate it dude!
  12. Mar 1, 2020 at 1:36 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    No problem. I had a 3" spacer lift "GASP" On a 2012 stock UCA and 285 75 17. They did rub just a hair on the UCA at full lock but it never hurt the tire and my alignment was in spec.
  13. Mar 1, 2020 at 1:39 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Yeah mine will be 5100’s front & rear. I didn’t want to go with a spacer lift. I just hope & pray I’ll be able to get away with 285/75/17 on stock UCA’s for a little until I can get new ones (if I have too) I might have to do a little trimming in the wheel well to help make them fit I do know that
  14. Mar 1, 2020 at 1:45 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    You'll be happy with them. Mine now ride good. I never trimmed anything. Just pulled the mud flaps. The UCA will really depend on how you use the truck. I think the suspension will articulate better with UCA's if you do any hard offloading. I used mine out in the oil field and beat on it pretty hard and never had any trouble. Have you done front hub assemblies yet? I would throw a set on while your at it. At least check them when you have it all apart. The 285's will take a worn out set a chew them up pretty quick. They are hard on them being so much heavier.
  15. Mar 1, 2020 at 1:49 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    The only off-roading I do is some dirt roads that take me out to where I hunt and fish and they are nothing excessive whatsoever. So hope I’ll still be able to get away with stock ones. And no I haven’t done hub assemblies yet, is it mandatory? And when you went up to 285s, did you have to re gear?
  16. Mar 1, 2020 at 1:57 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    No hubs aren't mandatory but with it being a 2009 just keep an eye on them. And no I didn't re gear. You'll be fine. I have 275 on my 09 now and next time I'm going 285 and staying at 2.5 lift. But I'm gonna open up the fenders and do a cab mount chop. It's a toy now some I'm gonna get a little stupid with it and make it capable but streetable with the suspension where it is. I kinda dig the lower stance with big tires look. And I won't have to spend a ton on suspension upgrades.
  17. Mar 1, 2020 at 2:13 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    Okay cool, thanks bro. Mines an 09 and just hit 46K miles yesterday so should be good, I’ll keep an eye on them. I wanna get the full 3” out of the lift and upgrade my tires to 285/75/17. Right now it’s stock suspension with 265/70/17
    dustinJ[QUOTED] likes this.
  18. Mar 1, 2020 at 3:32 PM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    If you go with OME leaf packs make sure to grease the leaf isolators or they will squeak and creek.
    dustinJ and TanzTacoma[OP] like this.
  19. Mar 1, 2020 at 4:09 PM
    TanzTacoma
    Tanner
    Boise, Idaho
    It’s just an add-a leaf but I’ll make sure to do that
  20. Mar 1, 2020 at 4:28 PM
    redz80
    Brampton, ON
    Last spring I did a 5100 kit with OME heavy duty leafs. After 6 months the squeaking and creaking started. Finally I saw this in another thread and it worked for me.
    If your only adding a extra leaf you most likly wont need to grease it.
    QUOTE="Lone Walnut, post: 17905645, member: 177149"]I was so close to removing the Dakars due to the severe squeaking. I had tried WD-40, fluid film, pressure washing, numerous varieties of oils and greases with relief only lasting a few days at best. I live and work in an area that has numerous dirt roads, so a combination of mud and dust has collected on the springs over the past year since installing. I have never greased the isolators/bushing/spacers. I separated the springs with a prybar and removed the spacers. The star shaped pattern on all of them was caked full of dirt that needed scraped and brushed to remove. I do believe this has been the problem. Packed full of lithium grease and fingers crossed. Time will tell. [/QUOTE]
