Bilstein 5100/5125 and OEM Springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by FatRoach, Mar 19, 2015.
  1. Mar 19, 2015 at 11:03 AM
    FatRoach
    FatRoach [OP] New Member
    Maine
    04 TRD
    Hi, I've looked around, and although many seem similar, I haven't seen the exact setup that I have with the same question.
    I currently have a 2004 TRD Double Cab with Bilstein 5100 in the front (set at "0"), 5125 in the rear - with NEW rear leafs (from getting frame replaced), but original coil springs in the front. I run Michelin LTX MS2 for tires at around 34psi.
    Although I like the control and capability it gives me off road (mainly dirt/logging roads) I still find it very stiff in general driving on pavement. I don't plan on getting any sort of lift (unless that would help stiffness somehow - doubt it). Any suggestions for helping with stiffness but still getting decent offroad capabiltiy? I've seen Eibach/OME suggestions, but again I have zero lift...
    Thanks in advance!
  2. Mar 19, 2015 at 12:19 PM
    stumpman
    stumpman Well-Known Member
    tn
    2019 Dclb cement
    I run the 5100s' on my truck set at 1.25 setting, ride is a little more firm, I am puzzled as to why yours would be stiff set a 0.
  3. Mar 19, 2015 at 12:48 PM
    FatRoach
    Maine
    04 TRD
    Thanks for your reply Stumpman. Me too. When I first bought the truck, it had the stock Toytec shocks, leafs, etc. At that point it was very stiff.
    After getting new leafs with the frame and Bilsteins in front and rear, I notice better control/handing/etc but not a HUGE difference in stiffness in general driving over bumps etc. Maine winters with frost heaves makes for quite a bouncy ride on pavement...
  4. Mar 19, 2015 at 1:12 PM
    byrdhntr
    byrdhntr Member
    Colorado
    03 TRD
    bone stock for now with ARE camper shell
    I would start by lowering your tire pressure a little. I run mine a 28 psi and it makes a big difference. It will cut your mpgs a little but it will help the ride.
  5. Mar 19, 2015 at 9:22 PM
    c3 rolling
    c3 rolling Well-Known Member
    Santa Clarita, CA
    04 PreRunner 3rz
    Maybe the OEM springs are worn out. Try replacing the spring with a new one.
