Bilstein 5100 + AAL help
Discussion in 'Suspension' started by tiger041988, May 7, 2012.
  1. May 7, 2012 at 1:27 PM
    tiger041988
    tiger041988 [OP] Active Member
    07 4WD SR5 stock
    Hey guys,
    Went to install my 2" AAL the other day and my rear shocks could use a swap. I'm putting bilstein 5100 adjustables in the front and figure I should match them in the back and go with the 5100 non adjustables. My question is, which shocks do I need? The 0-1.5" lift or the 3"-4" lift? Probably a really stupid question but I'm just curious because when I initally bought the AAL I called toytec and they said that the stock rear shocks would be sufficent, but now that I'm going to be replacing them I figure I would get the right ones.
    I'm also not opposed to going with a different shock, something maybe a little less $ but will do the trick if anyone has any suggestions. As always any input is helpful. Thanks guys.
  2. May 7, 2012 at 1:30 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Depends on what your usage will be. For light trail riding or on road driving, the stock travel 5100's will be fine. If you really like to flex out the truck, you might want to consider the extended travel shocks but might have to do something about your bump stops (you want to make sure the bump stops hit before the shock bottoms out). Talk to someone like Downsouth Motorsports and they'll get you set up with what you need.
  3. May 7, 2012 at 1:31 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Are you talking about the 5150's instead of the 5100's? You should be fine with the 5100's, I had those on my truck with a 2" AAL for a couple of years before I swapped out to reservoirs.
  4. May 7, 2012 at 1:32 PM
    tiger041988
    07 4WD SR5 stock
    Little to no offroading for at least a couple years.
  5. May 7, 2012 at 1:34 PM
    Pugga
    Massachusetts
    There are 2 lengths for the 5100's and the 2" AAL officially puts you in that grey area between the two.
    The standard length 5100's would be fine. I'm running 2" of lift with those shocks and haven't had any issues.
  6. May 7, 2012 at 1:35 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh I didnt know the 5100's came in two lengths? I thought the longer ones were the 5150's.:cool:
  7. May 7, 2012 at 1:40 PM
    tiger041988
    07 4WD SR5 stock
    My only other question is would throwing on some others (KYB, Monroe, rancho, etc) conflict at all?
  8. May 7, 2012 at 1:40 PM
    Pugga
    Massachusetts
    On DSM's site, they say the standard travel 5100's are for 0 - 1" rear lift and the extended travel are 3 - 4" of lift so a 2' AAL puts you in no man's land.
    You can go with 5125 or 5150 but they require the eye to stem adapter which causes you to lose a couple inches of travel due to the adapter length.
  9. May 7, 2012 at 1:43 PM
    Pugga
    Massachusetts
    Shouldn't, just make sure they're valved well enough to dampen the stiffer rear because of the AAL.
  10. May 7, 2012 at 4:11 PM
    tiger041988
    07 4WD SR5 stock
  11. May 8, 2012 at 1:01 PM
    Wet Dog
    Wet Dog New Member
    Gulf Coast
    Nissan Frontier
    Not to threadjack, but what other shocks are okay for the 2" AAL? My boyfriend has the AAL on his 07 extended cab and I wanted to get him new shocks (he just hit 100k on the originals) but I want to make sure I get him a good set that will have the right amount of travel. He has a camper shell on the bed and tows his boat alot.
  12. May 8, 2012 at 1:06 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I went with DSM and got the 3-4" 5100's. The 0-1.5 are the same length as stock. So you aren't getting a longer shock just different valving. I recommend 3-4". And extend your bumpstop or just leave the bumpstops where they are at like most of those running the long 5100's.
  13. May 8, 2012 at 1:06 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
  14. May 8, 2012 at 1:15 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    OME makes a good set.
  15. May 8, 2012 at 1:55 PM
    tiger041988
    07 4WD SR5 stock
  16. May 8, 2012 at 1:56 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
  17. May 8, 2012 at 6:16 PM
    tiger041988
    07 4WD SR5 stock
    Yeah. I'm not opposed to paying more for the bilsteins, I just figure since I'm not gonna be doing any offloading a stockish shock should do.
  18. May 9, 2012 at 9:09 AM
    tiger041988
    07 4WD SR5 stock
    On toytec they say that these ProComps are longer than a "normal" shock but don't give a measurement. Will these work with my 2" AAL or are they more like the billy 5100 for the 3"-4" lifts?
  19. May 9, 2012 at 1:09 PM
    tiger041988
    07 4WD SR5 stock
    Spoke with toytec and the guy didn't know the length of the procomps but said either the KYBs or the procomps should be fine.
  20. May 9, 2012 at 1:32 PM
    tiger041988
    07 4WD SR5 stock
    I'm just gonna go with the KYBs. I can get them by the weekend so I can finally put all my new stuff on. My lift, wheels, and tires have been sitting in my garage since March.
