Bilstein 5100 adjustable questions
Discussion in 'Suspension' started by 2010browntacotrd, Jul 8, 2016.
  1. Jul 21, 2016 at 11:04 AM
    #41
    Flintridge
    Flintridge Member
    Atlanta
    2009 DC 4x4
    So I have a 2009 DC Sport 4x4 and my dealership has ordered by replacement leaf springs so I will be getting those installed soon. I haven't done anything to the suspension yet but want a small lift just to level it out and improve the off-road ride. I'm going to order 5100's for the front and need to know what setting to put it at. I've installed AAL and spacers before on my previous Taco but now don't have the time to do an install so thinking about getting a shop to install the 5100's before my leaf spring install at the dealer so I can get a free alignment. The new recall springs are 3+1 I believe so should I set the 5100's at 1.75 and pray its level??? Don't want the bro lean at all...
  2. Jul 21, 2016 at 11:10 AM
    #42
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That should level it out, but it's tricky to say for sure because every truck is different and different people get different amounts of lift from the same exact setting. Weird, I know. That should work fine though and if you don't like it, changing it up isn't too hard! It's going to ride a bit rough though
  3. Jul 21, 2016 at 1:06 PM
    #43
    Flintridge
    Flintridge Member
    Atlanta
    2009 DC 4x4
    You have use a press to install the 5100's into the coils to install correct?
    It will be rough with the stock coils? Is that the reason? If it rides a little stiffer than that will be fine, prefer that. Thanks for the help.
  4. Jul 21, 2016 at 1:16 PM
    #44
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    OP, I would put your Bilsteins in and set them at the height you want them at. Then have your shop make you a custom AAL to level the truck or keep the factory front rake. That's what I did initially.
    Sorry, tell a lie. I did 885 OME coils in the front with my billies set at 0. The shop then did a .5" AAL to level my truck. In the end though the idea is the same. Custom AAL to level the truck or get the factory stance back.
  5. Jul 21, 2016 at 6:33 PM
    #45
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's rough with stock coils because you're preloading the shock, and limiting travel. If you set them at 0 and got aftermarket coils to provide lift, it would ride smoother.
  6. Jul 24, 2016 at 10:41 PM
    #46
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Depends on how much sag the ass end has, throw the 5100's on at the desired setting & measure from there...
  7. Jul 25, 2016 at 2:48 PM
    #47
    Nashwaak1
    Nashwaak1 Well-Known Member
    NB, Canada
    2011 Tacoma TRD Sport
    Bilstien 5100 at 1.75, WeatherTech Floormats, AVS vent visors
    Sorry for all the questions, but can you remember what your numbers were when you had your alignment done? I'm having my trucked levelled this week at the 1.75 setting with the stock UCAs. Just want to make sure the garage does a good job with the alignment.
  8. Jul 25, 2016 at 2:59 PM
    #48
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Nope, no idea. I went to an old school place where I don't even know if they knew the numbers. All I know is that my truck drives great! The numbers you typically want to shoot for are 0 toe, 0 camber, and ~2.5 caster
  9. Aug 9, 2016 at 12:42 PM
    #49
    Svizzusi
    Svizzusi Lifted 2009 4x4 DCSB
    San Luis Obispo, CA
    Bilstein 5100/ OME 887/ 285/70/17 BFG KO2/ 17" ProComp 7032/ OME Dakar/ LR UCA/ Superbumps/ AllPro Flip Kit
    I have a 2009 dcsb 4x4 and Was thinking of buying from headstrong either the bilstein 5100/ 887/ Dakar/ LR UCA for 3 inch lift and 285 70 17 ko2 tires. Or getting the performance kit with 6112/5160/ Dakar. I wanted to get a 3 " lift so that I would have room for the 285's. Not sure if this kit would get me 3" and if I could use 285s. Also not sure if I would need and UCA with that kit either. I am definitely a newbie, but I want to do it right the first time with little regrets. Any help or suggestions would be helpful
  10. Aug 9, 2016 at 1:54 PM
    #50
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hop back to the other thread where I quoted you.
  11. Aug 9, 2016 at 10:19 PM
    #51
    Svizzusi
    San Luis Obispo, CA
    I guess if both kits would accommodate the 285 it comes down to quality and price. I can get the 6112 setup for the same money as the 5100 minus the UCAs. If I don't need the UCAs with the 6112 kit then that seems like the way to go. I don't know if the 6112 kit can get the full 3" or just 2.5" in which I wouldn't need the UCAs. I don't do a lot of off-roading. But I do want it to perform as best as possible and be as big of a lift without getting into a lot of money and having to alter my truck too much. I definitely want to stay within the 2.5 to 3". Thanks
  12. Aug 13, 2016 at 8:47 PM
    #52
    Svizzusi
    San Luis Obispo, CA
    Does anyone have pictures or a thread that can show what was needed to get trimmed to fit 33's with a 5100/887/LR UCA/ Dakar? Thanks TW fam
  13. Aug 14, 2016 at 8:18 AM
    #53
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    https://www.tacomaworld.com/threads/b-a-m-f-cmc-plates-cab-mount-chop.192527/
    Here's how to do a CMC. The rest varies per truck, which usually involves trimming plastic and hammering back a little metal thats hiding behind the plastic (pinch weld)
  14. Aug 14, 2016 at 4:05 PM
    #54
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    I had the 5100s installed up front on stock Sport coils, 1.75 setting. The rear sits just a tad lower then stock when empty, so I'm wanting to install a 1" AAL in the back. I want to do the AAL install myself and was curious if I would need new U bolts and shocks on the rear also.
    I would imagine that lifting the rear would require a shock with more travel, but just asking if it's necessary with smaller AAL's such as a 1 inch.
  15. Aug 14, 2016 at 4:09 PM
    #55
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't believe anyone makes an AAL that small.
  16. Aug 14, 2016 at 4:17 PM
    #56
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Like he said. Smallest amount with an aal is 1.5". Leaf packs like the icons are usually 2", and if you remove the overload leaf it drops to 1.5".
  17. Aug 14, 2016 at 4:18 PM
    #57
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Your best bet is to just get a 1.5" AAL. I highly doubt you'll notice that fraction of an inch to the naked eye. Besides, a hair of rake looks good anyways.
    Chase8059[QUOTED] likes this.
  18. Aug 14, 2016 at 4:24 PM
    #58
    Chase8059
    Chase
    ESVA
    Thanks. So with a 1.5 AAL, new shocks and U bolts? The truck has about 12k on it.
  19. Aug 14, 2016 at 4:25 PM
    #59
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Don't need new U bolts, but you should get 5100s for the rear as well. You don't have to, but you should so you don't blow your stock shock.
  20. Aug 14, 2016 at 4:26 PM
    #60
    moondeath
    Pa, Gardners
    Usually comes with new u bolts, but if not its a good idea to get them. Shocks are recommended for the extra length. You dont absolutely need them if you dont flex the rear end. Its not as big of a deal.
