Bilstein 5100 adjustable shock instructions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by staplak, Dec 9, 2009.
  1. Dec 9, 2009 at 6:11 AM
    staplak
    staplak [OP] Well-Known Member
    Guntersville, AL
    04 Black Prerunner SR5 DoubleCab
    Thule Xsporter Rack
    I just got my bilsteins in and ready to put them on. Does anyone know where i can get some good directions. I think it will be pretty easy but i wanted to make sure I do not screw up something. I have already checked bilstein's website. Maybe some with pictures.
  2. Dec 9, 2009 at 2:03 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    I was pretty sure they came with instructions..
    It's a single sheet, with pictures.
  3. Dec 9, 2009 at 5:01 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (190k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ K&N air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    Most of it is pretty straightforward. If you search around on this forum you'll find good instructions. The rears are simple, but I used the following from Janster to work on the fronts:
    "If you look at the Steps 1-5 on this write up, it'll tell you how to remove the coil strut assembly from the truck.
    http://www.lieblweb.com/tacoma/Mecha...ft/Daystar.htm"
    If you can't find sufficient instructions and torque specs let me know and I'll type something up for you. I was starting from scratch and found everything I needed within the forum. Good luck, and let me know if I can help.
  4. Dec 9, 2009 at 5:04 PM
    Dashe
    Dashe Well-Known Member
    David
    Charleston
    Black Double Cab SR5 4x4
    debadged, Grillcraft grille with FJ emblem, KC SlimLite Driving Lights behind grille, Bilstein 5100's, Eibach 1.6" lift springs, add-a-leaf, Pro Comp 7089 wheels, BFGoodrich A/T 285/75/16, Dynomax Super Turbo muffler, CB with Wilson Flex antenna
    here is the best i could find online. it is actually the diagram that comes for the 5100s for tundras, but other than that its exactly the same. just substitute the numbers with 0", .85", 1.75", and 2.5"
  5. Dec 9, 2009 at 5:12 PM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    Thank you all I just got them put on today. Not as bad as it seemed. I set the front at 2.5 and the back with 1.5 shackles. The truck is not as level as i hoped it would be but oh well.
  6. Dec 9, 2009 at 6:51 PM
    smuook
    smuook Daily Driver "Plus"
    Frank
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    I have the same setup... it's not perfectly level, but I'm happy with it. You really have to look at it to notice the slight rake (less than before). The new height is great though.
  7. Sep 18, 2014 at 12:56 PM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    which notch did you use?
  8. Sep 18, 2014 at 2:11 PM
    wcp0611
    wcp0611 Well-Known Member
    Cliff
    Rockvale, TN
    wcp0611@gmail.com
    Grey wire and keyless entry. I like stock.
    2.5 is the top notch
  9. Sep 18, 2014 at 2:35 PM
    teamcurtis
    Curtis
    San Diego
    ahhh I missed where he said 2.5
  10. Sep 19, 2014 at 7:53 AM
    teamcurtis
    Curtis
    San Diego
    ^ was waiting for that.....
    "first"
