Bilstein 5100 Adjustable Shock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingtaco352, Jan 15, 2016.
  1. Jan 15, 2016 at 10:06 PM
    kingtaco352
    kingtaco352 [OP] New Member
    I am looking into purchasing the Bilstien 5100 Adjustable shock for my 2010 SR5 PreRunner. is there anything to know before buying these? Good or Bad? and do they really level out the vehicle on their own without anything else needed? What size tire should will be able to fit under if they were set at 2.5 in only the front?
    Thanks
  2. Jan 15, 2016 at 10:08 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Decent.
    Not at 2.5.
    265/75/16 or 265/70/17.
  3. Jan 15, 2016 at 10:09 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Is this a joke?
  4. Jan 15, 2016 at 10:09 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    They are great inexpensive shocks with multiple perches. The 5100's work with oem spring but pair nicely with the Toytec spring as its a little longer.
    Rides great on and off road.
  5. Jan 15, 2016 at 10:10 PM
    T4RFTMFW
    Calm your tits, Kelly.
    ecgreen, ChadsPride and TacoTaco15 like this.
  6. Jan 15, 2016 at 10:13 PM
    T4RFTMFW
    To add, I ran them at the .85 setting and loved them. They made my truck level with the 3 leaf (2+1 overload) rear leaf pack that my truck had.
    Most people with a 4 leaf OEM pack (3+1 overload) run the 5100s at 1.75 and it levels them out, occasionally it looks nose high to me but it could be camera angles and things, but maybe not.
    If you run them at 2.5 they'll be quite stiff riding and will negatively effect driveability.
    At 1.75 with an in spec alignment my truck drove poorly, though it handled well.
  7. Jan 16, 2016 at 8:58 AM
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    :frusty::facepalm:
    BrettBretterson likes this.
  8. Jan 16, 2016 at 9:00 AM
    T4RFTMFW
    As in brake dive was gone, it handled well in corners with the extra stiffness - but it drove like total shit, tons of bump steer, darting while braking, and followed every low spot in the road and made my fiancée nervous to drive it.
    Bruh.
    TacoTaco15 and ChadsPride like this.
  9. Jan 16, 2016 at 9:02 AM
    Thelgord
    Augusta, GA
    So ... it handled well in corners ... then had tons of bumper steer ... when cornering?
  10. Jan 16, 2016 at 9:08 AM
    mxracer244
    mxracer244 Well-Known Member
    Michael
    Quad Cities
    2016 TRD Sport DCSB
    My lift is at 1.75" and I experience none of the issues that DCSBFTMFW has pointed out. I would suggest to re-check your alignment. Sounds like you have issues with that more than the lift itself.
  11. Jan 16, 2016 at 9:08 AM
    Thelgord
    Augusta, GA
    I am actually very interested in this, since I am thinking of buying these exact same shocks. I currently have a 2.5" spacer lift on factory suspension and I have NONE of these issues.
  12. Jan 16, 2016 at 10:10 AM
    T4RFTMFW
    Well do a little reading, bro. There are a lot of people with the issues I outlined with 5100s at 1.75 and at 2.5.
  13. Jan 16, 2016 at 10:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    run my 5100's at 1.75in setting with SPC lightracing UCA's... caster set to 3.4*, truck drives like a dream... MUCH better than with the stock uca that i was only able to get ~1.5* of caster out of.
  14. Jan 16, 2016 at 10:24 AM
    T4RFTMFW
    this.
    I needed UCAs at 1.75, which is why I never buy into the only needed at 2.5" buzzing.
    To clarify for the guy who isn't running these, my truck cornered great. It was the 99% of driving in a straight line that sucked.
  15. Jan 16, 2016 at 10:29 AM
    nd4spdbh
    SoCal
    it also has alot to do with if you lift the rear. People that go level or bro lean have an easier time getting caster numbers as the whole frame is tilted back. In my case i wanted to keep rake so when i load the truck and actually use it like a truck im not dragging my hitch everywhere looking like a looser. So i did 2 inches of lift all around. This made it harder for me to get my caster numbers as the frame was tilted forward.
    That stated it wasnt terrible at 1.5* of caster but i knew it could be better. Also HATED how the uca hit coil at droop, the SPC arm fixed both those issues.
  16. Jan 16, 2016 at 10:39 AM
    CodeTaco
    CodeTaco Well-Known Member
    HB, CA
    2008 Tacoma Access Cab 4x4 TRD
    Bilstein 5100s (f @ 1.75); 5100s rear; All Pro Expedition Springs; PowerStop slotted discs; Akebono ceramic pads; Wheeler's braided brake lines; Prodigy trailer-brake system; heavy duty towing set-up (for off-road trailer); WeatherTech mats (awesome); 5% Ceramic Tint; matching Snug Top (mid) with racks; Thule racks; dipped badges; 17" 2014 OEM 5-spoke 4-runner rims; 265/70/17 Bridgestone Desert Duelers (for now); Siriusxm radio; more on the want list...
    So, OP, the lesson here is: If you don't want your ole lady driving yer rig----set 'em high! :cool:
  17. Jan 16, 2016 at 10:52 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Have my new 5100s at .85", rides great... Yes, I had the alignment checked and adjusted after the install (as is recommended with any lift).
  18. Jan 16, 2016 at 11:09 AM
    black_cukui
    black_cukui Well-Known Member
    Patrick
    Riverside, ca
    2010 T4R SR5
    Since we are on the topic of adjustability, I have a question for the 5100 Gurus. Rears are 5100/Wheelers AAL, Fronts are 5100 set to .85 with Toytec/Eibach 112-620 (1.6). No aftermarket UCA's yet, so my question is.... If I want to level it out to match the rears, do I go with the next one up? or very highest one? I believe there are 4 settings? sorry I don't know the exact setting off top LOL. Also with leveling it up another notch or two will I NEED aftermarket UCA's or can I go with the stock UCA's for the time being.
  19. Jan 16, 2016 at 11:12 AM
    Thelgord
    Augusta, GA
    For those that are interested, 4 Wheel Parts seems to be the best price at $95.
  20. Jan 16, 2016 at 11:28 AM
    supra90140
    supra90140 Well-Known Member
    telford pa
    08 dbl cab 4x4 lb trd sport speedway blue tow pkg
    weather tech floor liners
    I just got a set off eBay for 279 for all 4. Gonna have them put on when I get a new frame
