Bilstein 5100 Adjustable Shocks Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Levi12345, May 15, 2013.
  1. May 15, 2013 at 5:26 PM
    Levi12345
    Levi12345 [OP] Active Member
    california
    02 Prerunner SR5
    I have a 2002 tacoma prerunner, which has a factory lift of about 2-3"
    I want to lift my front end another 2". (so 4-5" in front and 3" in back.)
    If i use Bilsteins 5100 adjustable shocks, and adjust them to 2", will it add onto the 3" i already had, making my lift about 4"
    Or will it be only 2", thus possibly lowering my truck an inch?[​IMG]
    Im confused about this, and if there are any other things i should know
    THANK YOU FOR THE REPLIES! IM NEW! I APPRECIATE IT![​IMG]
  2. May 15, 2013 at 5:32 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    It would add... on the first gen (pre 2005) tacoma's you set the shocks to 0" and it will add lift. with stock coils i think it should add at least a couple inches
  3. May 15, 2013 at 5:33 PM
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    I'm not really sure what factory lift you are talking about?
    but the Bilstien adjustables have 3 setting for 1st gens which are 0", .85", and 2.5".
    if it is a spacer lift that you currently have then I would assume that it would just add on because the spacer would stay and the bilstiens would preload up to the desired height. but the max lift from the bilsteins will be 2.5".
    This will however result in a very stiff ride. If you plan on offroading at all this would not necessarily be a suggested set up.
    Some one else chime in here.
  4. May 15, 2013 at 11:00 PM
    Levi12345
    california
    02 Prerunner SR5
    Sorry i meant that since prerunners have a higher "stock" height than a standard tacoma; with the shocks intalled, will it lift my truck 2" higher than it is currently?
    (My truck is stock, so i did not add any blocks or spacers)
    Thanks!
  5. May 15, 2013 at 11:01 PM
    Levi12345
    california
    02 Prerunner SR5
    So your saying if i install the shocks, it will add an aditional 2" to my stock height?
  6. May 15, 2013 at 11:07 PM
    scocar
    scocar Patron of the Farts
    1st gen 5100s have 3 settings: 0, 1.25, and 2.5. You move the clip to the position you want. From bottom to top on the shock tube, the lowest is 0, the middle is 1.25, the highest is for 2.5. If you set it on 0, it will be the same height as a stock Prerunner.
  7. May 15, 2013 at 11:16 PM
    Levi12345
    california
    02 Prerunner SR5
    Thanks! thats the answer i wanted to hear.
  8. May 15, 2013 at 11:17 PM
    scocar
  9. May 15, 2013 at 11:19 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  10. May 15, 2013 at 11:30 PM
    Levi12345
    california
    02 Prerunner SR5
  11. May 15, 2013 at 11:55 PM
    SVtaco03
    SVtaco03 Well-Known Member
    Stockton CA
    03 DC prerunner V6
    They are cheaper here, , however I do not know about the price of shipping.
  12. May 15, 2013 at 11:59 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Woah woah woah back it up. What is this "factory lift" you're speaking of?
  13. May 16, 2013 at 4:13 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    He explained it in post #4
  14. May 16, 2013 at 4:24 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Not the easiest to find out b4 u order either, I tried :(
    I didn't see any option for a shipping calculator, and it leads u straight to credit card info......u could call them tho.
