Bilstein 5100 advice
Discussion in 'Suspension' started by dylandercole, Aug 4, 2009.
  1. Aug 4, 2009 at 9:08 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    So i have a 03 4x4 with 3'' revtec coil spacers in the front and 2.5'' AALs in the rear. I recently ordered toytec rear shackles to give me the extra inch to clear the 33s i want to put on. So i have to get new shocks. I have heard good things about the bilstein 5100s but wanted to know if anyone had any advice on different shocks or these ones.
  2. Aug 4, 2009 at 10:42 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    the 5100's are good but i am not sure if they will be long enough for your lift, i think they are only good to 2", give Sonny a call at downsouthmotorsports and he will take care of you and tell you what would be best.
  3. Aug 4, 2009 at 10:45 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Check out the billstein 5125s. They are longer for a higher lifted rear
  4. Aug 5, 2009 at 1:06 PM
    dylandercole
    Dylan
    Thanks guys this is my first rig so all this is new to me. Ill look into the 5125s.
  5. Aug 5, 2009 at 1:14 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    Boulder Creek, CA (Nor-Cal)
    2010 SSM DCLB
    the billys I have are max 2.5" so you will probably need to go to the 5125s. I'm not 100% though but good luck!
