bilstein 5100 alternative?
Discussion in 'Suspension' started by malander, Jul 18, 2010.
  1. Jul 28, 2010 at 7:52 AM
    bikewrench
    bikewrench Well-Known Member
    East Coast
    01 4x4 xtra-cab 2.7l
    OME 881/struts, 1.5" aal w/ Nitro 9000s, Sirius
    I was in this dilemma a few weeks ago and I ended up going OME/881s. Best choice I could have made. The deciding factor that swayed me to the OME stuff was that I had the option of the trim packers to level out the ride if needed. I ordered my struts and one trim packer for the driver's side and it sits damn near level. The ride is amazing, handles firm, but rides smooth. Well worth the price difference.
    Good luck!
  2. Jul 28, 2010 at 11:53 AM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    awesome are you running nitrochargers as well? and how does the trim packer work?
  3. Jul 28, 2010 at 12:52 PM
    bikewrench
    East Coast
    Yes, I am running the OME struts and the 881s. The trimpackers are 5mm spacers that go under the spring perch to level the truck. The struts have a welded lip and for the perch to sit on, just drop the # of trim packers on there that you want and then the spring perch and assemble like the stock strut. I was advised to run one packer on the drive side to compensate for the gas tank and the front of the truck is pretty level. The fact that this adjustability was designed as part of the system made me feel better about being able to make future adjutments due to sag or addition on heavy accessories.
  4. Jul 28, 2010 at 12:57 PM
    malander
    max
    01 limited trd 4x4
    so just compress the spring somewhat and add in some trim packer?
  5. Jul 28, 2010 at 12:59 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    install them yourself, and save some $$, rent the spring compressor
  6. Jul 28, 2010 at 1:01 PM
    bikewrench
    East Coast
    No, you wanna put the trim packer on, then the spring perch followed by the coil and the top end components(bushings, washers and top hat). You will need to compress to add the top hat.
  7. Jul 28, 2010 at 1:07 PM
    malander
    max
    01 limited trd 4x4
    another question lol sorry guys but will trim packer work with other shocks other than the nitrochargers? they're about 250 for a set and I was thinking of getting something alittle cheaper liike bilstein factory replacements. thanks for all the help guys
  8. Jul 28, 2010 at 1:11 PM
    bikewrench
    East Coast
    I was told that the trim packers will only work on the OME struts. I was looking to go the factory Bilstein/881 route, but in the end decided that the piece of mind I got from having a strut/coil combo that was "designed" to be used together was the best choice. The best prices were Toytec for the struts/trim packer (w/ their forum discount) and I got the coils from TRDparts4u.com. Both were great places to deal with.
  9. Jul 28, 2010 at 1:15 PM
    malander
    max
    01 limited trd 4x4
    how much did it end up costing you?
  10. Jul 28, 2010 at 1:32 PM
    bikewrench
    East Coast
    Coils were like $142 + shipping and I think it was right around $265 shipped for the struts and packer. I also did an aal and shocks from Wheelers. I think it was right around $600 for all the parts.
  11. Jul 28, 2010 at 1:35 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
  12. Jul 28, 2010 at 1:56 PM
    malander
    max
    01 limited trd 4x4
    nice the local shop wants to buy all the parts to make their money but it actually ends up being about the same as getting everything with forum discounts although I am going to run bilstein 5100 shocks in the back since those are in.. of course rcd would have the lesser desirable 5100 shocks in stock lol. I think with labor and parts i'm looking at around 850 for everything
