Bilstein 5100 and eibach height misunderstanding
Discussion in 'Suspension' started by mjporvaznik, Apr 27, 2014.
  1. Apr 27, 2014 at 7:45 AM
    mjporvaznik
    mjporvaznik [OP] Member
    mike
    Wilmington, NC
    12 Tacoma SR5 4 cylinder 4X4
    I know I know, beating a dead horse... but I just installed my bilstein and eibach kit from toytec with the rear aal. My front end is only sitting about 1.7 inches higher than stock. I know the spring is advertised to give that amount of lift. My bilstein are set at zero per the toytec recommendation. My issue is, could I disassemble my springs again and set them at .85 so that I could actually get near the three inch lift? My rear end is sitting just about 2.5 inches higher as it sits right now. Oh also the is may be important I say toytec recommended that setting because I drive a 4 cylinder access cab.
  2. Apr 27, 2014 at 7:51 AM
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    You can change the setting or install the top place spacers to get what your looking for. I'm a set for sell if you want to go that route.
  3. Apr 27, 2014 at 7:55 AM
    mjporvaznik
    mike
    Wilmington, NC
    I'll most likely end up changing the setting. I just can't really figure out why toytec is advertising to use the lowest when it doesn't achieve the lift. Frustrating having to redo it.
  4. Apr 27, 2014 at 8:00 AM
    TRDtexasTaco
    JP
    06 TRD PreRunner
    When I did mine. (Dbc v6). I had the .85 setting with the little spacer things to get the full 3" lift. I'm not 100% sure about acs cabs though
  5. Apr 27, 2014 at 8:03 AM
    mjporvaznik
    mike
    Wilmington, NC
    Yeah I have heard the spacers are necessary for the del cab, but not the access cab. I just want to make sure other people with 4cyl or access cabs don't run into this same problem. I guess the only difference between the acs cab and del cab install should be the spacers.
  6. Apr 27, 2014 at 8:18 AM
    teehext
    teehext Well-Known Member
    Tyler
    CA
    2001 PreRunner SR5
    I know for 1st gens you have to use the 0" setting when installing 5100/Eibachs. Maybe toytec got their instructions mixed up?
  7. Apr 27, 2014 at 8:23 AM
    mjporvaznik
    mike
    Wilmington, NC
    Good call, that could be it. I emailed them just aski my if they could explain it further. This way maybe they can fix the website and save some double work. Guess it's time for more beer and busted knuckles.
  8. Apr 27, 2014 at 10:05 AM
    mjporvaznik
    mike
    Wilmington, NC
    Also just wanted to add my measurments in case anyone was wondering. After bilsteins set at 0 and eibach springs added the front with a 2" aal in the back. (Non Tsb original leaf pack)
    21.5" hub to fender (front)
    24" hub to fender (rear)
  9. Apr 30, 2014 at 11:43 AM
    camo junkie
    camo junkie Well-Known Member
    Greg
    Kansas
    2014 Tacoma Sport 4x4
    3" lift OME lift 887 coils, LR UCA's, 16" Stealth Custom Series Wheels and 265/75/16 Duratrac Tires
    Here's my 2008 access cab V6 with Eibachs, Billies @ .85, 2" AAL's and Light Racing UCA's. I haven't measured but I can tell it's close to 3" of lift.
  10. May 1, 2014 at 5:37 AM
    mjporvaznik
    mike
    Wilmington, NC
    Here is my 2012 acs cab 4 cylinder with the 5100 and eibachs. this is after I adjusted the front bilstein to .85. I now measure roughly 22.5 front and 24 rear. granted the aal has not settled yet. When I had the front set at 0 per toytec instructons it looked like a funny car.
  11. May 1, 2014 at 6:04 AM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    If you asked for a 3" lift then Toytec screwed up by telling you to set them at the zero lift setting. If you stated that you wanted your truck level then the zero setting is where it should be.
    Either way, your truck looks nice with the 2.5". If you wanted the full 3" lift then you could go with the 1/4" top plate spacers.
