Bilstein 5100 and tire questions
Discussion in 'Wheels & Tires' started by BlueXenon, Mar 26, 2010.
  1. Mar 26, 2010 at 1:10 AM
    BlueXenon
    BlueXenon [OP] Well-Known Member
    Los Angeles and Newport Coast
    2024 Solar Octane TRD Sport (current) 2022 Lunar Rock TRD Sport (SOLD) 2020 Cement TRD sport (SOLD) 2009 Magnetic gray TRD sport (SOLD) 2004 Radiant Red TRD Off Road (SOLD)
    I have a prerunner double cab and the time has come to order the
    5100's. I currently have the TSB in the rear. If I were to set the 5100's
    at 1.75, do I still need to get a 1.5 AAL? Or is the factory TSB enough?
    My next question is for tires. I am planning on saving some $$$ by keeping the factory 17" TRD Sport wheels and having them powdercoated at a buddies shop. What's the widest tire I can fit on there and avoid rubbing? I know that without lifting I can squeeze a 265/70/17. Will the added lift give any room for a wider tire?
  2. Mar 26, 2010 at 1:33 AM
    DBZ 2010
    DBZ 2010 Well-Known Member
    Kahului, Maui
    2010 Wht Dbl Cab TRD Off Road PreRunner
    Gaylord TL Series Tonneau, 3 TSB's (Trans Re-flash, Rear Leaf Springs, Intermediate Steering Shaft), 5100 Bilsteins x 4 set at 1.75, Silver TRD FJ 16 inch Wheels, Wet Okoles
    The TSB rear springs are enough for the 1.75 settings. Thats what I got on my 10' dbl cab. :thumbsup:
  3. Mar 26, 2010 at 10:53 AM
    BlueXenon
    Thanks for the tip, not adding a AAL will save me some. Your truck looks great with that setup. Anyone shed some light on tires???
  4. Mar 26, 2010 at 10:59 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Now when you say wider? Do you mean left to right or taller up and down? I believe you should be able to fit at least some 31"s with the front lifted 1.75"s, maybe even bigger but I'm not positive. I know with a 2.5" lift you can fit 32"s and possible 33"s with some minor trimming.;)
  5. Mar 26, 2010 at 11:02 AM
    BlueXenon
    I meant wider from side to side. My stock duelers are 265/65/17, I know 265/70/17's will fit, just wondering if I can go wider from side to side without any rubbing.
